跳转到主内容
加入维修社区 - 创建账户
BOSE SoundTouch 30 Subwoofer Replacement
你所需要的
  1. BOSE SoundTouch 30 Subwoofer Replacement, Base Plate: 步骤 1 中的图像 1,2 BOSE SoundTouch 30 Subwoofer Replacement, Base Plate: 步骤 1 中的图像 2,2
    • Remove the four 15.5 mm PH2 screws securing the base plate to the device.
    询问修复机器人
    添加评论
  2. BOSE SoundTouch 30 Subwoofer Replacement, Power Supply: 步骤 2 中的图像 1,1
    • Remove the six 15.5mm PH2 screws securing the grille and rear panel to the device.
    询问修复机器人
    添加评论
  3. BOSE SoundTouch 30 Subwoofer Replacement: 步骤 3 中的图像 1,2 BOSE SoundTouch 30 Subwoofer Replacement: 步骤 3 中的图像 2,2
    • Remove the grille and rear panel by grabbing the corners and pulling upwards and outwards.
    • There is a small ribbon cable that connects the display assembly to the body of the device. Make sure to disconnect the cable before pulling the grille all the way off or else the cable could snap.
    添加评论
  4. BOSE SoundTouch 30 Subwoofer Replacement: 步骤 4 中的图像 1,1
    • Remove all four 15.5 mm PH2 screws holding the power supply down.
    • The power supply is identified by a green board with a large metal covering.
    添加评论
  5. BOSE SoundTouch 30 Subwoofer Replacement: 步骤 5 中的图像 1,2 BOSE SoundTouch 30 Subwoofer Replacement: 步骤 5 中的图像 2,2
    • Disconnect the three cables from the power supply by squeezing the white tabs if present and gently pulling.
    • Pick up the power supply and remove the fourth cable from the underside of the power supply.
    • Remove the power supply.
    添加评论
  6. BOSE SoundTouch 30 Subwoofer Replacement, Motherboard: 步骤 6 中的图像 1,3 BOSE SoundTouch 30 Subwoofer Replacement, Motherboard: 步骤 6 中的图像 2,3 BOSE SoundTouch 30 Subwoofer Replacement, Motherboard: 步骤 6 中的图像 3,3
    • Remove the five 15.5 mm PH2 screws holding the motherboard down.
    • Remove the three cables from the side of the motherboard by squeezing the grey tabs if present and gently pulling.
    • Remove the motherboard.
    • The motherboard is identified as the smaller green board with an ethernet, USB Type A, and an auxiliary port.
    添加评论
  7. BOSE SoundTouch 30 Subwoofer Replacement, Subwoofer: 步骤 7 中的图像 1,1
    • Remove the eight 15.5 mm PH2 screws holding the plastic insert down.
    • Remove the plastic insert.
    询问修复机器人
    添加评论
  8. BOSE SoundTouch 30 Subwoofer Replacement: 步骤 8 中的图像 1,1
    • Remove the three 15.5 mm PH2 screws holding the metal insert down.
    • Remove the metal insert.
    询问修复机器人
    添加评论
  9. BOSE SoundTouch 30 Subwoofer Replacement: 步骤 9 中的图像 1,1
    • Remove the three 19 mm PH2 screws holding the metal subwoofer cover down.
    • Remove the subwoofer cover.
    询问修复机器人
    添加评论
  10. BOSE SoundTouch 30 Subwoofer Replacement: 步骤 10 中的图像 1,1
    • Remove the four 19 mm PH2 screws holding the subwoofer in place.
    • Be careful not to let the screwdriver slip and damage the fragile subwoofer.
    询问修复机器人
    添加评论
  11. BOSE SoundTouch 30 Subwoofer Replacement: 步骤 11 中的图像 1,2 BOSE SoundTouch 30 Subwoofer Replacement: 步骤 11 中的图像 2,2
    • Remove the subwoofer by pulling towards the back of the device while tucking the wire under the plastic enclosure.
    添加评论
结论
取消:我没有完成这个指南。
2等其他人完成本指南。
Brennen Irey
于04/18/18注册
1,269 声望
创作了6篇指南
团队
Cal Poly, Team S16-G2, Livingston Spring 2018 Cal Poly, Team S16-G2, Livingston Spring 2018 的会员
CPSU-LIVINGSTON-S18S16G2
4 名成员
创作了8篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 35
总计 5,636
