简介
The display should be replaced in the event that it gets damaged beyond reasonable repair. Removing the display requires some caution due to the fragile nature of the ribbon connector.
你所需要的
Remove the grille by gripping the edges and pulling upwards.
What happens if you do snap the ribbon cable? Where and how can you find a replacement for it?
Tria Green - 回复
Remove the six 8.9mm T9 torx screws holding the display assembly down.
The display assembly can now be lifted out of the grille so that a new one can be put in.
2等其他人完成本指南。
