跳转到主内容
BMX Handlebars Replacement
你所需要的
  1. BMX Handlebars Replacement, BMX Handlebars: 步骤 1 中的图像 1,1
    • Locate the stem of the bike connecting the handlebars to the steerer tube of the fork.
  2. BMX Handlebars Replacement: 步骤 2 中的图像 1,2 BMX Handlebars Replacement: 步骤 2 中的图像 2,2
    • Remove the four bolts from the face of stem with a 6mm Allen key.
    • BMX bolts typically use a 6mm standard, but some equipment may differ.
  3. BMX Handlebars Replacement: 步骤 3 中的图像 1,1
    • Remove the faceplate of the stem.
  4. BMX Handlebars Replacement: 步骤 4 中的图像 1,1
    • Remove the old handlebars.
    • Place the new bars in the curved area of the stem where the old bars were located.
  5. BMX Handlebars Replacement: 步骤 5 中的图像 1,1
    • Place the faceplate of the stem back on and align the screw holes.
  6. BMX Handlebars Replacement: 步骤 6 中的图像 1,1
    • Insert the four screws back into the stem and tighten them half way with the 6mm Allen wrench.
  7. BMX Handlebars Replacement: 步骤 7 中的图像 1,2 BMX Handlebars Replacement: 步骤 7 中的图像 2,2
    • Align your handlebars so they are straight, balanced, and to your liking.
    • Tighten the bolts in an "X" pattern a half turn at a time.
  8. BMX Handlebars Replacement: 步骤 8 中的图像 1,1
    • Pull up on your handlebars and make sure they are tight enough that they do not move.
结论
To reassemble your device, follow these instructions in order.
另外一个人完成了本指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 24
总计 1,002
