跳转到主内容
加入维修社区 - 创建账户
BMX Chain Sprocket Replacement
你所需要的
  1. BMX Chain Sprocket Replacement, BMX Chain Sprocket: 步骤 1 中的图像 1,2 BMX Chain Sprocket Replacement, BMX Chain Sprocket: 步骤 1 中的图像 2,2
    • Flip the bike upside down in a position where the back wheel can spin freely.
    • Gather your tools.
  2. BMX Chain Sprocket Replacement: 步骤 2 中的图像 1,2 BMX Chain Sprocket Replacement: 步骤 2 中的图像 2,2
    • Get a ratchet, socket, extension and connect the extension to the socket and the ratchet to the extension.
    • Insert the socket with the extension in the peg till it hits the end.
    • Loosen the nut inside the peg.
    • Repeat these steps for the other side.
  3. BMX Chain Sprocket Replacement: 步骤 3 中的图像 1,2 BMX Chain Sprocket Replacement: 步骤 3 中的图像 2,2
    • Push the wheel forward till it stops, and there is no gap.
  4. BMX Chain Sprocket Replacement: 步骤 4 中的图像 1,2 BMX Chain Sprocket Replacement: 步骤 4 中的图像 2,2
    • Grab the chain
    • Slightly pull the chain to the side, away and back from the wheel
    • Make sure that it isn't attached to the wheel driver (spikes that chain sits on normally to make bike wheel move)
    • Make sure to keep an eye out for your fingers because you can get your hand caught between the chain and the wheel
  5. BMX Chain Sprocket Replacement: 步骤 5 中的图像 1,3 BMX Chain Sprocket Replacement: 步骤 5 中的图像 2,3 BMX Chain Sprocket Replacement: 步骤 5 中的图像 3,3
    • Grab the chain by the sprocket on the bottom of the bike
    • Pick it up and slightly pull to the side to remove the chain from the sprocket
    • Spin bike cranks to create clearance to move chain away from the sprocket and off the cranks
  6. BMX Chain Sprocket Replacement: 步骤 6 中的图像 1,2 BMX Chain Sprocket Replacement: 步骤 6 中的图像 2,2
    • Grab the Allen key that fits the compression bold
    • Loosen the compression bold
    • Completely remove the compression bold from the cranks
  7. BMX Chain Sprocket Replacement: 步骤 7 中的图像 1,2 BMX Chain Sprocket Replacement: 步骤 7 中的图像 2,2
    • Use the Allen key that fits the smaller bolt to loosen the cranks.
    • Loosen the bolt on the cranks.
    • Do not remove the bolt.
  8. BMX Chain Sprocket Replacement: 步骤 8 中的图像 1,3 BMX Chain Sprocket Replacement: 步骤 8 中的图像 2,3 BMX Chain Sprocket Replacement: 步骤 8 中的图像 3,3
    • Pull crank with the sprocket off the crank spindle.
    • Loosen the bolt that is holding sprocket (optional depending if cranks have the bolt).
    • Remove the sprocket from crank.
  9. BMX Chain Sprocket Replacement: 步骤 9 中的图像 1,3 BMX Chain Sprocket Replacement: 步骤 9 中的图像 2,3 BMX Chain Sprocket Replacement: 步骤 9 中的图像 3,3
    • Place the new sprocket on the cranks with the corresponding hole to hold the sprocket still.
    • Tighten the bolt to keep the sprocket in place (optional depending on bike cranks).
    • Push the cranks back onto the crank spindle still it stops moving and the other crank isn't pushed out.
    • Make sure that the crank is placed well and balanced.
  10. BMX Chain Sprocket Replacement: 步骤 10 中的图像 1,3 BMX Chain Sprocket Replacement: 步骤 10 中的图像 2,3 BMX Chain Sprocket Replacement: 步骤 10 中的图像 3,3
    • Thread in the crank compression bolt by hand on the cranks.
    • Use the Allen wrench to tighten the compression bolt and compress the crank and the crank spindle together.
  11. BMX Chain Sprocket Replacement: 步骤 11 中的图像 1,1
    • Use the Allen key to tighten the smaller compression bolt and prevent the cranks from spinning.
  12. BMX Chain Sprocket Replacement: 步骤 12 中的图像 1,3 BMX Chain Sprocket Replacement: 步骤 12 中的图像 2,3 BMX Chain Sprocket Replacement: 步骤 12 中的图像 3,3
    • Spin the crank with the sprocket to the position where the pedal is close to the peg.
    • Grab the chain.
    • Hover over the pedal to where you can place the chain back onto the sprocket.
    • Make sure that the chain is placed correctly on the sprocket.
    • Make sure to keep an eye out for your fingers because you can get your hand caught between the chain and the wheel.
  13. BMX Chain Sprocket Replacement: 步骤 13 中的图像 1,3 BMX Chain Sprocket Replacement: 步骤 13 中的图像 2,3 BMX Chain Sprocket Replacement: 步骤 13 中的图像 3,3
    • Place the chain back on the the wheel drive on the back wheel.
    • Spin the back wheel backwards so the chain can get rotation and sit correctly on the driver.
  14. BMX Chain Sprocket Replacement: 步骤 14 中的图像 1,2 BMX Chain Sprocket Replacement: 步骤 14 中的图像 2,2
    • Pull the back wheel till it stops moving.
    • Align the wheel so it wont hit either side of the frame.
  15. BMX Chain Sprocket Replacement: 步骤 15 中的图像 1,3 BMX Chain Sprocket Replacement: 步骤 15 中的图像 2,3 BMX Chain Sprocket Replacement: 步骤 15 中的图像 3,3
    • Use the socket with ratchet and the extension to tighten the nut inside the peg slightly, which will allow the wheel to move slightly if needed.
    • Do the same thing on the other side.
    • Once the wheel is aligned, tighten one side slightly and then tighten the other side slightly as well.
    • Keep doing this process until the nuts are tightened enough to they won't move without the use of the ratchet.
  16. BMX Chain Sprocket Replacement: 步骤 16 中的图像 1,1
    • Flip the bike right side up and the bike is ready to go.
结论
The new bike sprocket will be installed if bike sprocket was broken or wanted a new one
Andy Barrientos
于04/03/23注册
253 声望
撰写一个指南
团队
CSU Los Angeles, Team H-99, Briggs Spring 2023 CSU Los Angeles, Team H-99, Briggs Spring 2023 的会员
CSULA-BRIGGS-S23SHG99
1 名成员
创作了1篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 49
总计 1,205
