跳转到主内容
BMW M-Colored LED Front Kidney Grille Installation
你所需要的
  1. BMW M-Colored LED Front Kidney Grille Installation, Prep Work: 步骤 1 中的图像 1,1
    • You will need to remove a couple of bolts on the front bumper before you can start removing the BMW factory kidney grille.
  2. BMW M-Colored LED Front Kidney Grille Installation, Taking out the factory kidney grille: 步骤 2 中的图像 1,3 BMW M-Colored LED Front Kidney Grille Installation, Taking out the factory kidney grille: 步骤 2 中的图像 2,3 BMW M-Colored LED Front Kidney Grille Installation, Taking out the factory kidney grille: 步骤 2 中的图像 3,3
    • When you have enough clearance space, you can wedge your hand in between the gap to pop out the stock kidney grille.
    • Keep maneuvering your hand in the space to ease the stock grille out.
  3. BMW M-Colored LED Front Kidney Grille Installation, Watch out for the clips: 步骤 3 中的图像 1,1
    • Detach the stock kidney grille from the clips holding it onto the BMW front bumper.
  4. BMW M-Colored LED Front Kidney Grille Installation, Starting the swap: 步骤 4 中的图像 1,2 BMW M-Colored LED Front Kidney Grille Installation, Starting the swap: 步骤 4 中的图像 2,2
    • Pull out the factory kidney grille.
  5. BMW M-Colored LED Front Kidney Grille Installation, Putting in the new LED kidney grille: 步骤 5 中的图像 1,2 BMW M-Colored LED Front Kidney Grille Installation, Putting in the new LED kidney grille: 步骤 5 中的图像 2,2
    • Use your hand to apply a bit of pressure to pop the new LED M-stripe kidney grille in place
    • Secure the new LED grille onto the clips.
    • Note: the M-Colored LED stripe is only on the right grille assembly.
    • Tap the wire to the ACC or other 12V power source.
    • Repeat on the other side.
  6. BMW M-Colored LED Front Kidney Grille Installation, Put everything back: 步骤 6 中的图像 1,1
    • Put the bolts back into the BMW front bumper.
    • Enjoy your new M-Colored BMW LED Illuminated kidney grille.
结论
You can see that you didn't need to be an advanced car installer to attempt this. This makes the installation great for beginners as well as seasoned car fans alike.
2等其他人完成本指南。
Eric Wu
于01/21/15注册
3,327 声望
创作了23篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 10
过去 30 天: 50
总计 9,549
