跳转到主内容
BMW F10 M5 LED Reverse Light Installation
你所需要的
  1. BMW F10 M5 LED Reverse Light Installation, BMW F10 M5 Reverse Lights: 步骤 1 中的图像 1,1
    • Gain access to the back of the trunk
    • Remove some clips that hold the trunk liner in place.
    • Tip: You don't have to remove all the clips, just enough so you have enough access.
  2. BMW F10 M5 LED Reverse Light Installation: 步骤 2 中的图像 1,1
    • Pull out the bulb tray.
    • Press the two clips on the side to release.
  3. BMW F10 M5 LED Reverse Light Installation: 步骤 3 中的图像 1,2 BMW F10 M5 LED Reverse Light Installation: 步骤 3 中的图像 2,2
    • Remove the bulb and swap it out with the new LED bulb.
  4. BMW F10 M5 LED Reverse Light Installation: 步骤 4 中的图像 1,2 BMW F10 M5 LED Reverse Light Installation: 步骤 4 中的图像 2,2
    • Test to see if the LED reverse lights work and enjoy.
结论
Installation will take absolutely no time at all and you will be on your way to some new LED reverse lights.
3等其他人完成本指南。
Eric Wu
于01/21/15注册
3,327 声望
创作了23篇指南
一条评论
Any idea how to do this on the Station Wagon/ Tourer model F11d
The liner does not have easily removable clips. The tool box cover reveals several screws and 2 recessed expanding plastic catches which I cant get out . Removed all the screws has not impact.
Thanks
david meredith - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 20
总计 9,535
