跳转到主内容
BMW 2003-2010 5 Series Tail Light Bulb Replacement
你所需要的
  1. BMW 2003-2010 5 Series Tail Light Bulb Replacement, Tail light Bulb: 步骤 1 中的图像 1,1
    • Open the trunk of the car to access the tail lights.
    • Remove the two 5 mm screws holding the panel cover in place.
  2. BMW 2003-2010 5 Series Tail Light Bulb Replacement: 步骤 2 中的图像 1,1
    • With a flathead screwdriver, turn the screws half a turn counterclockwise.
  3. BMW 2003-2010 5 Series Tail Light Bulb Replacement: 步骤 3 中的图像 1,1
    • With plyers, remove the screws.
  4. BMW 2003-2010 5 Series Tail Light Bulb Replacement: 步骤 4 中的图像 1,3 BMW 2003-2010 5 Series Tail Light Bulb Replacement: 步骤 4 中的图像 2,3 BMW 2003-2010 5 Series Tail Light Bulb Replacement: 步骤 4 中的图像 3,3
    • Pull up the trunk matt and remove it from the corner.
    • Pull up the panel by the tab.
    • The panel should lift right out.
  5. BMW 2003-2010 5 Series Tail Light Bulb Replacement: 步骤 5 中的图像 1,3 BMW 2003-2010 5 Series Tail Light Bulb Replacement: 步骤 5 中的图像 2,3 BMW 2003-2010 5 Series Tail Light Bulb Replacement: 步骤 5 中的图像 3,3
    • You will see the light bulb holster.
    • Turn the dial in the middle of of the black plastic light bulb holster.
    • Pull the holster out of the trunk bay.
  6. BMW 2003-2010 5 Series Tail Light Bulb Replacement: 步骤 6 中的图像 1,1
    • Grab the light bulb at the base and twist counterclockwise.
    • DO NOT TWIST THE BULB BY THE GLASS.
  7. BMW 2003-2010 5 Series Tail Light Bulb Replacement: 步骤 7 中的图像 1,1
    • Pull out the bulb and repeat the process in reverse order with the new bulb to reassemble.
结论
To reassemble, follow these instructions in reverse order.
另外一个人完成了本指南。
Christophe Chedid
于03/22/21注册
169 声望
撰写一个指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 26
过去 30 天: 184
总计 2,953
