跳转到主内容
BLU WIN HD LTE Battery Replacement
你所需要的
  1. BLU WIN HD LTE Battery Replacement, Back Case: 步骤 1 中的图像 1,1
    • Pry the back cover from the bottom of the phone, pulling outwards and upwards.
  2. BLU WIN HD LTE Battery Replacement: 步骤 2 中的图像 1,1
    • Fully remove the cover and set aside in a safe place.
  3. BLU WIN HD LTE Battery Replacement, Frame Cover: 步骤 3 中的图像 1,1
    • Remove all the nine 2mm screws using the JIS #00 Screwdriver.
  4. BLU WIN HD LTE Battery Replacement: 步骤 4 中的图像 1,1
    • Pry the frame off using the spudger pulling upwards going to different areas around the device.
    • The back cover is secured by glue. Removal could be more difficult than expected.
  5. BLU WIN HD LTE Battery Replacement, Battery: 步骤 5 中的图像 1,2 BLU WIN HD LTE Battery Replacement, Battery: 步骤 5 中的图像 2,2
    • Remove the battery out using the black nylon spudger.
    • Battery is secured by glue so use more force to take it out.
结论
2条评论
I replaced the battery but now there is a symbol on the screen, box with a question mark, what does that mean?
raybrooks - 回复
I hope someone else has had this issue an has a solution. Thank you in advance for any and all help.
raybrooks - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 664
