跳转到主内容
BLU Vivo XL2 LCD Screen Replacement
你所需要的
  1. BLU Vivo XL2 LCD Screen Replacement, Removing the back cover: 步骤 1 中的图像 1,3 BLU Vivo XL2 LCD Screen Replacement, Removing the back cover: 步骤 1 中的图像 2,3 BLU Vivo XL2 LCD Screen Replacement, Removing the back cover: 步骤 1 中的图像 3,3
    • locate the edge the phone, to find a easy entre point, then using a Isesamo opening tool to open the four sides, and removed back cover.
  2. BLU Vivo XL2 LCD Screen Replacement, Removing metal bracket: 步骤 2 中的图像 1,3 BLU Vivo XL2 LCD Screen Replacement, Removing metal bracket: 步骤 2 中的图像 2,3 BLU Vivo XL2 LCD Screen Replacement, Removing metal bracket: 步骤 2 中的图像 3,3
    • After removed the Back Plastic Cover, a metal bracket is covering the battery connector and the LCD screen connector. Removed all the screws in the metal bracket, then removed the Metal Bracket. Now, disconnect the two connectors of the LCD and Battery.
  3. BLU Vivo XL2 LCD Screen Replacement, Disconnect LCD screen and Battery Connector: 步骤 3 中的图像 1,2 BLU Vivo XL2 LCD Screen Replacement, Disconnect LCD screen and Battery Connector: 步骤 3 中的图像 2,2
    • After removed the metal bracket, you will see the two connectors, disconnect them
  4. BLU Vivo XL2 LCD Screen Replacement, Lifting up the battery, removed both connectors: 步骤 4 中的图像 1,2 BLU Vivo XL2 LCD Screen Replacement, Lifting up the battery, removed both connectors: 步骤 4 中的图像 2,2
    • Here is tough part of all, the battery had two stripe of adhesive at tha bottom to secured it down. Just like the Iphone 6, you can carefully pull the adhesive stripe out or using tool to lift up the battery on the side where the connector of the battery located. After lift the battery up, disconnect the both connectors.
  5. BLU Vivo XL2 LCD Screen Replacement, Separate LCD Screen: 步骤 5 中的图像 1,1
    • Using a heat gun or other tool to apply some heat to the screen, making the glue softing and using tool to separate the screen. Be carfully at the bottom where the flex connection.
  6. BLU Vivo XL2 LCD Screen Replacement, install new LCD Screen: 步骤 6 中的图像 1,3 BLU Vivo XL2 LCD Screen Replacement, install new LCD Screen: 步骤 6 中的图像 2,3 BLU Vivo XL2 LCD Screen Replacement, install new LCD Screen: 步骤 6 中的图像 3,3
    • After the damaged LCD screen were removed, install the new LCD screen, remember the flex and connector need to go thought the small opening below the battery. Connecting back both connectors, and secure the metal bracket on top of the battery.
  7. BLU Vivo XL2 LCD Screen Replacement, Test new LCD Screen and Charging Port: 步骤 7 中的图像 1,3 BLU Vivo XL2 LCD Screen Replacement, Test new LCD Screen and Charging Port: 步骤 7 中的图像 2,3 BLU Vivo XL2 LCD Screen Replacement, Test new LCD Screen and Charging Port: 步骤 7 中的图像 3,3
    • After put back all the screws in the Metal bracket, time to test the new LCD Screen. Connecting the charger, to see the charging port is functional, then do a power on to verified the LCD Screen working or not. If both working as they should, job almost done. Now put back the Back Plastic Cover and we call it done.
  8. BLU Vivo XL2 LCD Screen Replacement, A working Blu VIVO XL 2 phone!!: 步骤 8 中的图像 1,1
    • A working Blu VIVO XL 2 phone!!
结论
另外一个人完成了本指南。
nickzhao2010
于09/17/18注册
157 声望
撰写一个指南
1指南评论
Where is the best place to get parts
JEFFREY G BRYANT - 回复
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 12
过去 30 天: 24
总计 2,040
