跳转到主内容
加入维修社区 - 创建账户
BLU Tank II Outer Lens Replacement
你所需要的
  1. BLU Tank II Outer Lens Replacement, Back Panel: 步骤 1 中的图像 1,2 BLU Tank II Outer Lens Replacement, Back Panel: 步骤 1 中的图像 2,2
    • With the screen facing you, find the left corner of the phone. There should be a visible groove.
    • With your fingers, carefully press a fingernail into the slot and separate the back panel from the phone.
  2. BLU Tank II Outer Lens Replacement, Battery: 步骤 2 中的图像 1,1
    • After the back panel has been removed, put your finger on and press down on the bottom part of the battery.
    • Lift the battery up and carefully remove the battery.
  3. BLU Tank II Outer Lens Replacement, Front Panel: 步骤 3 中的图像 1,2 BLU Tank II Outer Lens Replacement, Front Panel: 步骤 3 中的图像 2,2
    • Using the phillips head screwdriver, remove all 5 2.5mm screws.
  4. BLU Tank II Outer Lens Replacement: 步骤 4 中的图像 1,1
    • Wedge the blue plastic iFixit opening tool between the front plate and the outer lens plate.
    • Carefully separate the front plate from all sides of the phone.
  5. BLU Tank II Outer Lens Replacement, Motherboard: 步骤 5 中的图像 1,2 BLU Tank II Outer Lens Replacement, Motherboard: 步骤 5 中的图像 2,2
    • Locate the two 2.5mm screws (red circles in image) and remove them with the Philips 00 screwdriver used previously.
  6. BLU Tank II Outer Lens Replacement: 步骤 6 中的图像 1,3 BLU Tank II Outer Lens Replacement: 步骤 6 中的图像 2,3 BLU Tank II Outer Lens Replacement: 步骤 6 中的图像 3,3
    • Once screws are removed, separate the motherboard and outer lens by carefully pushing the motherboard out with your hand as displayed in the image.
  7. BLU Tank II Outer Lens Replacement, Outer Lens: 步骤 7 中的图像 1,2 BLU Tank II Outer Lens Replacement, Outer Lens: 步骤 7 中的图像 2,2
    • Once separated from the motherboard, the outer lens can now be replaced.
结论
David Kelchner
于03/08/17注册
632 声望
创作了6篇指南
团队
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 14
总计 241
