跳转到主内容
BLU Tank II Keypad Replacement
你所需要的
  1. BLU Tank II Keypad Replacement, Back Panel: 步骤 1 中的图像 1,2 BLU Tank II Keypad Replacement, Back Panel: 步骤 1 中的图像 2,2
    • With the screen facing you, find the left corner of the phone. There should be a visible groove.
    • With your fingers, carefully press a fingernail into the slot and separate the back panel from the phone.
  2. BLU Tank II Keypad Replacement, Battery: 步骤 2 中的图像 1,1
    • After the back panel has been removed, put your finger on and press down on the bottom part of the battery.
    • Lift the battery up and carefully remove the battery.
  3. BLU Tank II Keypad Replacement, Front Panel: 步骤 3 中的图像 1,2 BLU Tank II Keypad Replacement, Front Panel: 步骤 3 中的图像 2,2
    • Using the phillips head screwdriver, remove all 5 2.5mm screws.
  4. BLU Tank II Keypad Replacement: 步骤 4 中的图像 1,1
    • Wedge the blue plastic iFixit opening tool between the front plate and the outer lens plate.
    • Carefully separate the front plate from all sides of the phone.
  5. BLU Tank II Keypad Replacement, Keypad: 步骤 5 中的图像 1,3 BLU Tank II Keypad Replacement, Keypad: 步骤 5 中的图像 2,3 BLU Tank II Keypad Replacement, Keypad: 步骤 5 中的图像 3,3
    • Once the front plate is separated from the outer lens plate, place your fingers on the backside of the keypad.
    • Peel the keypad out from the keyholes in the front plate.
结论
David Kelchner
于03/08/17注册
632 声望
创作了6篇指南
团队
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 10
总计 237
