跳转到主内容
BLU Studio 7.0 II Rear Camera Replacement
你所需要的
  1. BLU Studio 7.0 II Rear Camera Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Locate the seam between the black and silver pieces of the phone.
    • Insert a plastic opening tool into the seam and firmly pry the black back piece away from the silver front piece.
    • To create the initial separation for the plastic opening tool, you may need to use either a spudger or metal spudger. If you use a metal spudger, be aware this can damage your phone if you aren't careful.
  2. BLU Studio 7.0 II Rear Camera Replacement: 步骤 2 中的图像 1,1
    • Work your way around the edge of phone, firmly prying the pieces apart.
  3. BLU Studio 7.0 II Rear Camera Replacement: 步骤 3 中的图像 1,2 BLU Studio 7.0 II Rear Camera Replacement: 步骤 3 中的图像 2,2
    • Once the back has been removed, you can snap the new one into place by pressing firmly around the edges with your fingers.
  4. BLU Studio 7.0 II Rear Camera Replacement, Rear Camera: 步骤 4 中的图像 1,2 BLU Studio 7.0 II Rear Camera Replacement, Rear Camera: 步骤 4 中的图像 2,2
    • The camera is located in the top left of the frame (if the screen is on the table and the top of the phone is farthest from you).
    • To remove it, grip the lens itself (the black part) with a pair of precision tweezers and lift straight up.
    • The camera is connected to the motherboard with a simple clip connection. This will release as you pull.
结论
另外一个人完成了本指南。
Abby
于05/14/16注册
852 声望
创作了5篇指南
团队
Metro State, Team 1-2, Carpenter SU 2016 Metro State, Team 1-2, Carpenter SU 2016 的会员
MSU-CARPENTER-SU16S1G2
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 5
总计 375
