跳转到主内容
BLU Studio 5.0 S II Motherboard Replacement
你所需要的
  1. BLU Studio 5.0 S II Motherboard Replacement, Remove back cover: 步骤 1 中的图像 1,1
    • Remove the back cover of the phone with the plastic opening tool, or your fingers.
  2. BLU Studio 5.0 S II Motherboard Replacement, Remove battery: 步骤 2 中的图像 1,1
    • Remove the battery from the phone with the plastic opening tool, or your fingers.
  3. BLU Studio 5.0 S II Motherboard Replacement, Motherboard: 步骤 3 中的图像 1,2 BLU Studio 5.0 S II Motherboard Replacement, Motherboard: 步骤 3 中的图像 2,2
    • Remove the microSD and SIM card. Gently tug on the microSD and SIM card to slide them out of their insert.
  4. BLU Studio 5.0 S II Motherboard Replacement: 步骤 4 中的图像 1,2 BLU Studio 5.0 S II Motherboard Replacement: 步骤 4 中的图像 2,2
    • Locate the 5 black 3.5mm screws and the 1 3.5mm silver screw on the top back plate.
    • Remove the 6 3.5mm screws by using a Phillips #00 screwdriver.
  5. BLU Studio 5.0 S II Motherboard Replacement: 步骤 5 中的图像 1,2 BLU Studio 5.0 S II Motherboard Replacement: 步骤 5 中的图像 2,2
    • Remove the inner top back black plate.
  6. BLU Studio 5.0 S II Motherboard Replacement: 步骤 6 中的图像 1,2 BLU Studio 5.0 S II Motherboard Replacement: 步骤 6 中的图像 2,2
    • Locate the 2 black 3.5mm screws on the motherboard.
    • Remove the black 3.5 mm screws using a Phillips #00 screwdriver.
  7. BLU Studio 5.0 S II Motherboard Replacement: 步骤 7 中的图像 1,3 BLU Studio 5.0 S II Motherboard Replacement: 步骤 7 中的图像 2,3 BLU Studio 5.0 S II Motherboard Replacement: 步骤 7 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Locate the 2 orange ribbons on opposite sides.
    • Carefully remove the two ribbon cables using tweezers.
    • Gently rock the cable back and forth equally from both sides to not damage the pins.
  8. BLU Studio 5.0 S II Motherboard Replacement: 步骤 8 中的图像 1,2 BLU Studio 5.0 S II Motherboard Replacement: 步骤 8 中的图像 2,2
    • Gently rock the plastic opening tool back and forth until the motherboard releases from the phone.
    • Adhesion, identified with red circles, bonds the motherboard to the chassis. This may require extra effort to lift off from back of phone.
  9. BLU Studio 5.0 S II Motherboard Replacement: 步骤 9 中的图像 1,2 BLU Studio 5.0 S II Motherboard Replacement: 步骤 9 中的图像 2,2
    • Follow the wire from the motherboard.
    • Remove the black lining covering the wire.
  10. BLU Studio 5.0 S II Motherboard Replacement: 步骤 10 中的图像 1,2 BLU Studio 5.0 S II Motherboard Replacement: 步骤 10 中的图像 2,2
    • Locate the 5 black screws on inner black lower plate.
  11. BLU Studio 5.0 S II Motherboard Replacement: 步骤 11 中的图像 1,2 BLU Studio 5.0 S II Motherboard Replacement: 步骤 11 中的图像 2,2
    • Remove the bottom inner back plate.
  12. BLU Studio 5.0 S II Motherboard Replacement: 步骤 12 中的图像 1,2 BLU Studio 5.0 S II Motherboard Replacement: 步骤 12 中的图像 2,2
    • Holding the cable with the removal tool, gently pull in the direction of the cable to remove the connector from its socket.
  13. BLU Studio 5.0 S II Motherboard Replacement: 步骤 13 中的图像 1,1
    • Remove the whole motherboard.
    • The Motherboard contains the headphone jack and the power button.
结论
To reassemble your device, follow these instructions in reverse order with the new motherboard.
另外一个人完成了本指南。
Aaron Isaacs
于03/01/17注册
107 声望
撰写一个指南
团队
IUPUI, Team S2-G3, Harley Spring 2017 IUPUI, Team S2-G3, Harley Spring 2017 的会员
IUPUI-HARLEY-S17S2G3
4 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 12
总计 478
