跳转到主内容
BLU Studio 5.0 II Volume Button Replacement
你所需要的
  1. BLU Studio 5.0 II Volume Button Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn off your phone before disassembling the device.
    • Locate the small opening on the bottom corner of the back case.
  2. BLU Studio 5.0 II Volume Button Replacement: 步骤 2 中的图像 1,2 BLU Studio 5.0 II Volume Button Replacement: 步骤 2 中的图像 2,2
    • Use your finger to open the back case by slowly pulling it on the open slot.
    • Once the case is lifted on the corner, slide your finger along the edge of the phone to remove the rest of the case.
  3. BLU Studio 5.0 II Volume Button Replacement: 步骤 3 中的图像 1,3 BLU Studio 5.0 II Volume Button Replacement: 步骤 3 中的图像 2,3 BLU Studio 5.0 II Volume Button Replacement: 步骤 3 中的图像 3,3
    • Locate the opening slot at the bottom of the battery.
    • Use your finger to lift the battery and remove it from the case.
  4. BLU Studio 5.0 II Volume Button Replacement, Back Case: 步骤 4 中的图像 1,1
    • Locate the four 3mm screws on each side of the back panel.
    • Use a Phillips #00 screwdriver to remove the eight screws.
  5. BLU Studio 5.0 II Volume Button Replacement: 步骤 5 中的图像 1,3 BLU Studio 5.0 II Volume Button Replacement: 步骤 5 中的图像 2,3 BLU Studio 5.0 II Volume Button Replacement: 步骤 5 中的图像 3,3
    • Carefully use a spudger to start opening the back case by inserting it between the black and blue lines on the side of the phone.
    • With the help of your fingers, continue to remove the back case by sliding it through the opening.
  6. BLU Studio 5.0 II Volume Button Replacement, Volume Button: 步骤 6 中的图像 1,2 BLU Studio 5.0 II Volume Button Replacement, Volume Button: 步骤 6 中的图像 2,2
    • Locate the volume button on the right side of the phone after removing back case.
    • Using a spudger carefully wedge between button and phone and carefully pry away from the phone.
    • Once removed the yellow buttons will be visible.
结论
2等其他人完成本指南。
Zack Miliziano
于02/09/16注册
146 声望
撰写一个指南
团队
USF Tampa, Team 7-5, Cheng Spring 2016 USF Tampa, Team 7-5, Cheng Spring 2016 的会员
USFT-CHENG-S16S7G5
3 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 13
总计 222
