跳转到主内容
BLU Studio 5.0 II Back Case Replacement
你所需要的
  1. BLU Studio 5.0 II Back Case Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn off your phone before disassembling the device.
    • Locate the small opening on the bottom corner of the back case.
  2. BLU Studio 5.0 II Back Case Replacement: 步骤 2 中的图像 1,2 BLU Studio 5.0 II Back Case Replacement: 步骤 2 中的图像 2,2
    • Use your finger to open the back case by slowly pulling it on the open slot.
    • Once the case is lifted on the corner, slide your finger along the edge of the phone to remove the rest of the case.
  3. BLU Studio 5.0 II Back Case Replacement: 步骤 3 中的图像 1,3 BLU Studio 5.0 II Back Case Replacement: 步骤 3 中的图像 2,3 BLU Studio 5.0 II Back Case Replacement: 步骤 3 中的图像 3,3
    • Locate the opening slot at the bottom of the battery.
    • Use your finger to lift the battery and remove it from the case.
  4. BLU Studio 5.0 II Back Case Replacement, Back Case: 步骤 4 中的图像 1,1
    • Locate the four 3mm screws on each side of the back panel.
    • Use a Phillips #00 screwdriver to remove the eight screws.
  5. BLU Studio 5.0 II Back Case Replacement: 步骤 5 中的图像 1,3 BLU Studio 5.0 II Back Case Replacement: 步骤 5 中的图像 2,3 BLU Studio 5.0 II Back Case Replacement: 步骤 5 中的图像 3,3
    • Carefully use a spudger to start opening the back case by inserting it between the black and blue lines on the side of the phone.
    • With the help of your fingers, continue to remove the back case by sliding it through the opening.
结论
另外一个人完成了本指南。
Ricardo Sarabia
于02/09/16注册
1,069 声望
创作了6篇指南
团队
USF Tampa, Team 7-5, Cheng Spring 2016 USF Tampa, Team 7-5, Cheng Spring 2016 的会员
USFT-CHENG-S16S7G5
3 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 13
总计 401
