跳转到主内容
BLU Life XL Volume Control Buttons Replacement
你所需要的
  1. BLU Life XL Volume Control Buttons Replacement, Volume Control Buttons: 步骤 1 中的图像 1,3 BLU Life XL Volume Control Buttons Replacement, Volume Control Buttons: 步骤 1 中的图像 2,3 BLU Life XL Volume Control Buttons Replacement, Volume Control Buttons: 步骤 1 中的图像 3,3
    • Turn the device off by holding down the power button for up to 5 seconds and then tapping the "Power off" button on the screen.
    • Remove the rear cover using your hands at the lip on the device back cover. No tools required.
    • Remove the battery by lifting the lower edge of the battery up first.
  2. BLU Life XL Volume Control Buttons Replacement: 步骤 2 中的图像 1,2 BLU Life XL Volume Control Buttons Replacement: 步骤 2 中的图像 2,2
    • Remove the 12x3mm screws from the rear plate using the Phillips#000 screwdriver.
  3. BLU Life XL Volume Control Buttons Replacement: 步骤 3 中的图像 1,2 BLU Life XL Volume Control Buttons Replacement: 步骤 3 中的图像 2,2
    • Firmly press the prying tool into the gap between the front glass and rear plate. This gap is located on all sides of the phone.
    • Run the prying tool around the entire phone separating the rear plate from the frame.
  4. BLU Life XL Volume Control Buttons Replacement: 步骤 4 中的图像 1,3 BLU Life XL Volume Control Buttons Replacement: 步骤 4 中的图像 2,3 BLU Life XL Volume Control Buttons Replacement: 步骤 4 中的图像 3,3
    • Gently remove the tape covering the volume control buttons. The tape is located near the top left of the cavity for the battery.
    • Replace the component and reapply the tape over the buttons.
结论
James Whitlow
于02/14/18注册
342 声望
创作了3篇指南
团队
USF Tampa, Team S2-G5, Eyestone Spring 2018 USF Tampa, Team S2-G5, Eyestone Spring 2018 的会员
USFT-EYESTONE-S18S2G5
3 名成员
创作了5篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 10
总计 398
