跳转到主内容
BLU Life XL Rear Camera Replacement
你所需要的
  1. BLU Life XL Rear Camera Replacement, Rear Camera: 步骤 1 中的图像 1,3 BLU Life XL Rear Camera Replacement, Rear Camera: 步骤 1 中的图像 2,3 BLU Life XL Rear Camera Replacement, Rear Camera: 步骤 1 中的图像 3,3
    • Turn the device off by holding down the power button for up to 5 seconds and then tapping the "Power off" button on the screen.
    • Remove the rear cover using your hands at the lip on the device back cover. No tools required.
    • Remove the battery by lifting the lower edge of the battery up first.
  2. BLU Life XL Rear Camera Replacement: 步骤 2 中的图像 1,2 BLU Life XL Rear Camera Replacement: 步骤 2 中的图像 2,2
    • Remove the 12x3mm screws from the rear plate using the Phillips#000 screwdriver.
  3. BLU Life XL Rear Camera Replacement: 步骤 3 中的图像 1,2 BLU Life XL Rear Camera Replacement: 步骤 3 中的图像 2,2
    • Insert the plastic prying tool in between the plastic frame and the device.
    • Keep the phone on the surface with its screen down.
  4. BLU Life XL Rear Camera Replacement: 步骤 4 中的图像 1,2 BLU Life XL Rear Camera Replacement: 步骤 4 中的图像 2,2
    • Use the plastic prying tool to gently push the rear camera out from its socket.
    • Take the camera out and set it aside.
  5. BLU Life XL Rear Camera Replacement: 步骤 5 中的图像 1,2 BLU Life XL Rear Camera Replacement: 步骤 5 中的图像 2,2
    • Carefully place the new camera in the camera socket.
    • Apply a little force on the top of the camera to slide it in the socket.
    • Pop the camera in the socket and make sure its stable.
结论
Shantanu Malhotra
于02/14/18注册
178 声望
撰写一个指南
团队
USF Tampa, Team S2-G5, Eyestone Spring 2018 USF Tampa, Team S2-G5, Eyestone Spring 2018 的会员
USFT-EYESTONE-S18S2G5
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 6
总计 227
