跳转到主内容
BLU Life XL Charging Port Replacement
你所需要的
  1. BLU Life XL Charging Port Replacement, Battery: 步骤 1 中的图像 1,3 BLU Life XL Charging Port Replacement, Battery: 步骤 1 中的图像 2,3 BLU Life XL Charging Port Replacement, Battery: 步骤 1 中的图像 3,3
    • Turn the device off by holding down the power button for up to 5 seconds and then tapping the "Power off" button on the screen.
    • Remove the rear cover using your hands at the lip on the device back cover. No tools required.
  2. BLU Life XL Charging Port Replacement: 步骤 2 中的图像 1,3 BLU Life XL Charging Port Replacement: 步骤 2 中的图像 2,3 BLU Life XL Charging Port Replacement: 步骤 2 中的图像 3,3
    • Remove the old battery.
    • For optimal performance, calibrate your newly installed battery: Drain battery below 10%, then charge uninterrupted to 100%.
  3. BLU Life XL Charging Port Replacement, Charging Port: 步骤 3 中的图像 1,2 BLU Life XL Charging Port Replacement, Charging Port: 步骤 3 中的图像 2,2
    • Remove twelve 3mm Phillips #000 screws from the rear plate.
  4. BLU Life XL Charging Port Replacement: 步骤 4 中的图像 1,2 BLU Life XL Charging Port Replacement: 步骤 4 中的图像 2,2
    • Remove the plastic frame on the device using an opening tool.
    • Firmly press the tool into the gap between the front glass and rear plate.
    • The gap is located on all sides of the phone.
    • Run the tool through this gap along the entire edge of the phone to separate the plastic frame from the phone.
  5. BLU Life XL Charging Port Replacement: 步骤 5 中的图像 1,3 BLU Life XL Charging Port Replacement: 步骤 5 中的图像 2,3 BLU Life XL Charging Port Replacement: 步骤 5 中的图像 3,3
    • Disconnect lower PCB antenna connection.
    • Disconnect lower PCB data cable connection.
    • Remove the single JIS #000 3mm screw from the PCB board.
  6. BLU Life XL Charging Port Replacement: 步骤 6 中的图像 1,1
    • Remove the haptic motor at bottom left of the device. This will require a prying tool, as the motor is glued to the device.
结论
2等其他人完成本指南。
Euan Gordon
于02/14/18注册
164 声望
撰写一个指南
团队
USF Tampa, Team S2-G5, Eyestone Spring 2018 USF Tampa, Team S2-G5, Eyestone Spring 2018 的会员
USFT-EYESTONE-S18S2G5
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 1,910
