跳转到主内容
BLU Energy X Plus Battery Replacement
你所需要的
  1. BLU Energy X Plus Battery Replacement, Battery: 步骤 1 中的图像 1,2 BLU Energy X Plus Battery Replacement, Battery: 步骤 1 中的图像 2,2
    • Before disassembling your BLU Energy X Plus, make sure it is powered off.
    • Flip your device to the left side facing up and take out the SD card tray using the SIM card eject tool. You will insert the tool in at an angle and lift the tray up.
  2. BLU Energy X Plus Battery Replacement: 步骤 2 中的图像 1,2 BLU Energy X Plus Battery Replacement: 步骤 2 中的图像 2,2
    • Flip your device to the right side facing up and use the SIM card eject tool to remove the SIM card by pushing the tool in the hole. You will feel a button click and the tray should slide out 2mm. You will then use your fingers to pull the tray out.
  3. BLU Energy X Plus Battery Replacement: 步骤 3 中的图像 1,1
    • Flip your device over so your back cover is facing up.
  4. BLU Energy X Plus Battery Replacement: 步骤 4 中的图像 1,2 BLU Energy X Plus Battery Replacement: 步骤 4 中的图像 2,2
    • Take the blue plastic opening tool and insert it in-between the back of the phone and the chrome trim. Go all the way around the device slowly to take the back cover off.
  5. BLU Energy X Plus Battery Replacement: 步骤 5 中的图像 1,2 BLU Energy X Plus Battery Replacement: 步骤 5 中的图像 2,2
    • Remove the six silver screws from the cover plate, and one black screw from the top.
    • Use the screwdriver head J000 to remove all the screws.
    • Six silver screws, all 1.5mm in length.
    • One black screw, 1mm in length.
  6. BLU Energy X Plus Battery Replacement: 步骤 6 中的图像 1,1
    • After all the screws are out, lift the protective metal cover off of the phone. Lift from the bottom of the cover.
  7. BLU Energy X Plus Battery Replacement: 步骤 7 中的图像 1,1
    • Use the small blue plastic opening tool to lift the contact attached to the battery from the motherboard of the phone.
  8. BLU Energy X Plus Battery Replacement: 步骤 8 中的图像 1,2 BLU Energy X Plus Battery Replacement: 步骤 8 中的图像 2,2
    • Use the small blue plastic opening tool to lift the battery from the bottom with little force because the battery will be glued in.
    • Then, use your hand to remove the battery completely.
结论
5等其他人完成本指南。
woodjake94
于02/09/16注册
638 声望
创作了5篇指南
团队
USF Tampa, Team 2-121, Cagle Spring 2016 USF Tampa, Team 2-121, Cagle Spring 2016 的会员
USFT-CAGLE-S16S2G121
4 名成员
创作了5篇指南
2条评论
what about a Blu Energy XL
Anthony Johnson - 回复
Muito obrigada!
Estava com um travamento no sistema que impedia reiniciar o smartphone.
Depois de desconectar a bateria e conectar novamente o celular voltou ao normal!
Nicoli - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 6,261
