跳转到主内容
修复你的物品
维修的权力
商店
简介
You may need to replace the battery on the BLU Energy X Plus due to various reasons. This guide will show you how to open the BLU Energy X Plus and replace it's battery successfully with step-by-step instructions and pictures. This is an 8 step process that can be straightforward if you follow the steps provided throughout the guide.
  1. Before disassembling your BLU Energy X Plus, make sure it is powered off. Flip your device to the left side facing up and take out the SD card tray using the SIM card eject tool. You will insert the tool in at an angle and lift the tray up.
    • Before disassembling your BLU Energy X Plus, make sure it is powered off.
    • Flip your device to the left side facing up and take out the SD card tray using the SIM card eject tool. You will insert the tool in at an angle and lift the tray up.
  2. Flip your device to the right side facing up and use the SIM card eject tool to remove the SIM card by pushing the tool in the hole. You will feel a button click and the tray should slide out 2mm. You will then use your fingers to pull the tray out. Flip your device to the right side facing up and use the SIM card eject tool to remove the SIM card by pushing the tool in the hole. You will feel a button click and the tray should slide out 2mm. You will then use your fingers to pull the tray out.
    • Flip your device to the right side facing up and use the SIM card eject tool to remove the SIM card by pushing the tool in the hole. You will feel a button click and the tray should slide out 2mm. You will then use your fingers to pull the tray out.
  3. Flip your device over so your back cover is facing up.
    • Flip your device over so your back cover is facing up.
  4. 跳过升级
    通过使用多合一工具包维修可以节省成本。
    购买 iPhone 维修工具套装
    跳过升级
    通过使用多合一工具包维修可以节省成本。
    购买 iPhone 维修工具套装
  5. Take the blue plastic opening tool and insert it in-between the back of the phone and the chrome trim. Go all the way around the device slowly to take the back cover off. Take the blue plastic opening tool and insert it in-between the back of the phone and the chrome trim. Go all the way around the device slowly to take the back cover off.
    • Take the blue plastic opening tool and insert it in-between the back of the phone and the chrome trim. Go all the way around the device slowly to take the back cover off.
  6. Remove the six silver screws from the cover plate, and one black screw from the top. Use the screwdriver head J000 to remove all the screws.
    • Remove the six silver screws from the cover plate, and one black screw from the top.
    • Use the screwdriver head J000 to remove all the screws.
    • Six silver screws, all 1.5mm in length.
    • One black screw, 1mm in length.
  7. After all the screws are out, lift the protective metal cover off of the phone. Lift from the bottom of the cover.
    • After all the screws are out, lift the protective metal cover off of the phone. Lift from the bottom of the cover.
  8. Use the small blue plastic opening tool to lift the contact attached to the battery from the motherboard of the phone.
    • Use the small blue plastic opening tool to lift the contact attached to the battery from the motherboard of the phone.
  9. Use the small blue plastic opening tool to lift the battery from the bottom with little force because the battery will be glued in. Then, use your hand to remove the battery completely.
    • Use the small blue plastic opening tool to lift the battery from the bottom with little force because the battery will be glued in.
    • Then, use your hand to remove the battery completely.
结论
5等其他人完成本指南。
woodjake94
于2016年02月09日注册
638 信誉积分
创作了5篇指南
团队
USF Tampa, Team 2-121, Cagle Spring 2016 USF Tampa, Team 2-121, Cagle Spring 2016 的会员
USFT-CAGLE-S16S2G121
4 名成员
创作了5篇指南
what about a Blu Energy XL
Anthony Johnson - 回复
Muito obrigada!
Estava com um travamento no sistema que impedia reiniciar o smartphone.
Depois de desconectar a bateria e conectar novamente o celular voltou ao normal!
Nicoli Bernecoli - 回复
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 1
过去的30天: 7
总计 5,995
