跳转到主内容
BLU Dash Music 4.0 Speaker Replacement
你所需要的
  1. BLU Dash Music 4.0 Speaker Replacement, Remove the Back Cover: 步骤 1 中的图像 1,1
    • Use the plastic opening tool or your fingernail to pry off the back cover.
  2. BLU Dash Music 4.0 Speaker Replacement, Remove the Battery: 步骤 2 中的图像 1,1
    • Use the plastic opening tool or your fingernail to pry off the battery from the top right corner.
  3. BLU Dash Music 4.0 Speaker Replacement, Remove the Screws: 步骤 3 中的图像 1,2 BLU Dash Music 4.0 Speaker Replacement, Remove the Screws: 步骤 3 中的图像 2,2
    • Use a screwdriver to remove each of the four screws.
  4. BLU Dash Music 4.0 Speaker Replacement, Remove the Inner Cover: 步骤 4 中的图像 1,2 BLU Dash Music 4.0 Speaker Replacement, Remove the Inner Cover: 步骤 4 中的图像 2,2
    • Take the plastic opening tool and insert it in the crease between the front screen and the inner back cover.
    • Slide the plastic opening tool along the edge of the phone to pry the covers apart.
  5. BLU Dash Music 4.0 Speaker Replacement, Remove the Speaker: 步骤 5 中的图像 1,3 BLU Dash Music 4.0 Speaker Replacement, Remove the Speaker: 步骤 5 中的图像 2,3 BLU Dash Music 4.0 Speaker Replacement, Remove the Speaker: 步骤 5 中的图像 3,3
    • Locate the speaker
    • Wedge the plastic opening tool between the speaker and the circuit board. Gently pry the speaker off the circuit board.
    • Use a soldering iron to remove the two wires that connect the speaker to the circuit board.
  6. BLU Dash Music 4.0 Speaker Replacement, Place the New Speaker: 步骤 6 中的图像 1,1
    • Use the soldering iron to connect the two wires, that are attached to the speaker, to the circuit board.
    • Place the new speaker onto the circuit board.
结论
另外一个人完成了本指南。
团队
UMass Dartmouth, Team 6-8, Vijaybhaskar Fall 2014 UMass Dartmouth, Team 6-8, Vijaybhaskar Fall 2014 的会员
UMASSD-VIJAYBHASKAR-F14S6G8
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 9
总计 493
