跳转到主内容
BLU Dash Music 4.0 Micro USB Port Replacement
你所需要的
  1. BLU Dash Music 4.0 Micro USB Port Replacement, Remove Back Cover: 步骤 1 中的图像 1,1
    • Use the plastic opening tool or your fingernail to pry off the back cover.
  2. BLU Dash Music 4.0 Micro USB Port Replacement, Remove Battery: 步骤 2 中的图像 1,1
    • Use the plastic opening tool or your fingernail to pry off the battery from the top right corner.
  3. BLU Dash Music 4.0 Micro USB Port Replacement, Remove Screws: 步骤 3 中的图像 1,2 BLU Dash Music 4.0 Micro USB Port Replacement, Remove Screws: 步骤 3 中的图像 2,2
    • Use a screwdriver to remove each of the four screws.
  4. BLU Dash Music 4.0 Micro USB Port Replacement, Remove Inner Cover: 步骤 4 中的图像 1,2 BLU Dash Music 4.0 Micro USB Port Replacement, Remove Inner Cover: 步骤 4 中的图像 2,2
    • Take the plastic opening tool and insert it in the crease between the front screen and the inner back cover.
    • Slide the plastic opening tool along the edge of the phone such that the two covers are pulled apart.
  5. BLU Dash Music 4.0 Micro USB Port Replacement, Remove Black Pad: 步骤 5 中的图像 1,1
    • Insert the plastic opening tool between black pad and the circuit board. Then gently pry off the black pad.
    • This will make the connections of the charging port more accessible.
  6. BLU Dash Music 4.0 Micro USB Port Replacement, Remove Solder Connections: 步骤 6 中的图像 1,3 BLU Dash Music 4.0 Micro USB Port Replacement, Remove Solder Connections: 步骤 6 中的图像 2,3 BLU Dash Music 4.0 Micro USB Port Replacement, Remove Solder Connections: 步骤 6 中的图像 3,3
    • Using a soldering iron and a pair of pliers, melt the four soldering connections around the charging port.
    • Quickly pull off the current charging port while the soldering connections are still soft.
  7. BLU Dash Music 4.0 Micro USB Port Replacement, Mount New Charging Port: 步骤 7 中的图像 1,1
    • Mount the new charging port so that the four prongs of the charging port line up with the four soldering connections.
    • Using a soldering iron, solder the connections in place.
结论
另外一个人完成了本指南。
团队
UMass Dartmouth, Team 6-8, Vijaybhaskar Fall 2014 UMass Dartmouth, Team 6-8, Vijaybhaskar Fall 2014 的会员
UMASSD-VIJAYBHASKAR-F14S6G8
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 855
