跳转到主内容
BLU Dash Music 4.0 Headphone Jack Replacement
你所需要的
  1. BLU Dash Music 4.0 Headphone Jack Replacement, Remove the Back Cover: 步骤 1 中的图像 1,1
    • Use the plastic opening tool or your fingernail to pry off the back cover.
  2. BLU Dash Music 4.0 Headphone Jack Replacement, Remove the Battery: 步骤 2 中的图像 1,1
    • Use the plastic opening tool or your fingernail to pry off the battery from the top right corner.
  3. BLU Dash Music 4.0 Headphone Jack Replacement, Remove the Screws: 步骤 3 中的图像 1,2 BLU Dash Music 4.0 Headphone Jack Replacement, Remove the Screws: 步骤 3 中的图像 2,2
    • Use a screwdriver to remove each of the four screws.
  4. BLU Dash Music 4.0 Headphone Jack Replacement, Remove the Inner Cover: 步骤 4 中的图像 1,2 BLU Dash Music 4.0 Headphone Jack Replacement, Remove the Inner Cover: 步骤 4 中的图像 2,2
    • Take the plastic opening tool and insert it in the crease between the front screen and the inner back cover.
    • Slide the plastic opening tool along the edge of the phone to pry the two covers apart.
  5. BLU Dash Music 4.0 Headphone Jack Replacement, Remove the Black Pad: 步骤 5 中的图像 1,2 BLU Dash Music 4.0 Headphone Jack Replacement, Remove the Black Pad: 步骤 5 中的图像 2,2
    • Insert the plastic opening tool between the black pad and the circuit board. Then gently pry off the black pad.
    • This will make the connections of the charging port more accessible.
  6. BLU Dash Music 4.0 Headphone Jack Replacement, Remove the Solder Connections: 步骤 6 中的图像 1,2 BLU Dash Music 4.0 Headphone Jack Replacement, Remove the Solder Connections: 步骤 6 中的图像 2,2
    • Using a soldering iron and a pair of pliers, melt the soldering connections around the headphone jack.
    • Quickly pull off the current headphone jack while the soldering connections are still soft.
  7. BLU Dash Music 4.0 Headphone Jack Replacement, Mount the New Headphone Jack: 步骤 7 中的图像 1,1
    • Mount the new headphone jack such that the prongs of the headphone jack line up with the soldering connections.
    • Using a soldering iron, solder the connections in place.
结论
团队
UMass Dartmouth, Team 6-8, Vijaybhaskar Fall 2014 UMass Dartmouth, Team 6-8, Vijaybhaskar Fall 2014 的会员
UMASSD-VIJAYBHASKAR-F14S6G8
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 401
