跳转到主内容
BLU Dash 3.5 Ear Speaker Replacement
你所需要的
  1. BLU Dash 3.5 Ear Speaker Replacement, Battery: 步骤 1 中的图像 1,3 BLU Dash 3.5 Ear Speaker Replacement, Battery: 步骤 1 中的图像 2,3 BLU Dash 3.5 Ear Speaker Replacement, Battery: 步骤 1 中的图像 3,3
    • Start by locating the slot on the lower right corner of the device.
    • Insert the opening tool into the slot.
    • Pry the back cover off. Once the corner is off, continue around the perimeter of the phone pulling the back off with your fingers.
    • A fingernail can work to open the back in place of an opening tool.
  2. BLU Dash 3.5 Ear Speaker Replacement: 步骤 2 中的图像 1,2 BLU Dash 3.5 Ear Speaker Replacement: 步骤 2 中的图像 2,2
    • Locate the indentation at the bottom of the battery.
    • Insert your thumb and pull the battery out.
  3. BLU Dash 3.5 Ear Speaker Replacement, Volume and Lock Button: 步骤 3 中的图像 1,2 BLU Dash 3.5 Ear Speaker Replacement, Volume and Lock Button: 步骤 3 中的图像 2,2
    • Use the 000 Phillips screwdriver to remove the four 4.5 mm screws from the corners of the interior back panel.
    • Use the opening tool to pry open the plastic back panel to expose the motherboard.
  4. BLU Dash 3.5 Ear Speaker Replacement: 步骤 4 中的图像 1,2 BLU Dash 3.5 Ear Speaker Replacement: 步骤 4 中的图像 2,2
    • Remove volume and lock buttons by lifting them gently from the casing.
  5. BLU Dash 3.5 Ear Speaker Replacement, Ear Speaker: 步骤 5 中的图像 1,2 BLU Dash 3.5 Ear Speaker Replacement, Ear Speaker: 步骤 5 中的图像 2,2
    • Use tweezers to lift the screen wire tab where the cable is connected.
    • Use the opening tool to pry the motherboard from the front face plate.
  6. BLU Dash 3.5 Ear Speaker Replacement: 步骤 6 中的图像 1,1
    • Use opening tool to pry speaker from front panel.
    • Note prong direction
结论
Aaron Boehm
于03/01/17注册
201 声望
创作了2篇指南
团队
IUPUI, Team S1-G2, Harley Spring 2017 IUPUI, Team S1-G2, Harley Spring 2017 的会员
IUPUI-HARLEY-S17S1G2
4 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 5
总计 183
