跳转到主内容
BEM Mojo 2 Speaker Battery Replacement
你所需要的
  1. BEM Mojo 2 Speaker Battery Replacement, Speaker Battery: 步骤 1 中的图像 1,1
    • Pull back the rubber corners to uncover the bottom screws.
    • Continue this process for all four 10 mm screws.
  2. BEM Mojo 2 Speaker Battery Replacement: 步骤 2 中的图像 1,1
    • Use the J0 screwdriver to remove all four 10mm screws from the bottom of the speaker.
    • Caution: It is important when using the screwdriver to not use excessive force as this may strip the screw and can damage the speaker itself.
  3. BEM Mojo 2 Speaker Battery Replacement: 步骤 3 中的图像 1,1
    • Remove the bottom cover of the speaker.
    • Caution: Be careful when removing the bottom cover of the speaker as there are wires that connect to the speaker itself that become exposed upon base removal.
    • Remove all of the wires from the speakers internal chip, utilizing the tweezers.
    • Caution: Be careful not to damage the chip.
  4. BEM Mojo 2 Speaker Battery Replacement: 步骤 4 中的图像 1,1
    • Remove the speakers battery from its metal base, utilizing the plastic opening tool.
  5. BEM Mojo 2 Speaker Battery Replacement: 步骤 5 中的图像 1,1
    • Remove the wires from the speakers battery using the tweezers or by gently removing them by lightly pinching.
结论
Rachel Iacoboni
于01/30/18注册
618 声望
创作了5篇指南
团队
Baylor, Team S1-G1, Johnson Spring 2018 Baylor, Team S1-G1, Johnson Spring 2018 的会员
BU-JOHNSON-S18S1G1
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 12
总计 530
