跳转到主内容
BEM Mojo 2 Charging Base Motherboard Replacement
你所需要的
  1. BEM Mojo 2 Charging Base Motherboard Replacement, Charging Base Battery: 步骤 1 中的图像 1,1
    • Use the metal spudger to peel back the rubber from the bottom of the auxiliary charging base to reveal the screw.
  2. BEM Mojo 2 Charging Base Motherboard Replacement: 步骤 2 中的图像 1,1
    • Use the screwdriver with the J0 bit attatched to detach all four 10 mm screws from the charging base.
  3. BEM Mojo 2 Charging Base Motherboard Replacement: 步骤 3 中的图像 1,2 BEM Mojo 2 Charging Base Motherboard Replacement: 步骤 3 中的图像 2,2
    • Pull the top cover off of the charging base to reveal the internal chip.
    • Use the plastic opening tool to pry the battery from the top cover.
    • Caution: Be careful when detaching battery from top cover as to not damage any of the wires attached to it.
  4. BEM Mojo 2 Charging Base Motherboard Replacement: 步骤 4 中的图像 1,1
    • Use the tweezers to carefully detach the wires from the internal chip.
    • Caution: Be careful to not damage the internal chip when removing the wires.
  5. BEM Mojo 2 Charging Base Motherboard Replacement, Charging Base Motherboard: 步骤 5 中的图像 1,1
    • Use the tweezers to remove the red wire attached to the motherboard.
  6. BEM Mojo 2 Charging Base Motherboard Replacement: 步骤 6 中的图像 1,1
    • Use the plastic opening tool to carefully lift and remove the motherboard from the charging base.
结论
另外一个人完成了本指南。
Rachel Iacoboni
于01/30/18注册
618 声望
创作了5篇指南
团队
Baylor, Team S1-G1, Johnson Spring 2018 Baylor, Team S1-G1, Johnson Spring 2018 的会员
BU-JOHNSON-S18S1G1
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 10
总计 170
