跳转到主内容
B350M BAZOOKA Motherboard GPU Replacement
你所需要的
  1. B350M BAZOOKA Motherboard GPU Replacement, Graphics Processing Unit: 步骤 1 中的图像 1,1
    • Establish a clean work space.
  2. B350M BAZOOKA Motherboard GPU Replacement: 步骤 2 中的图像 1,3 B350M BAZOOKA Motherboard GPU Replacement: 步骤 2 中的图像 2,3 B350M BAZOOKA Motherboard GPU Replacement: 步骤 2 中的图像 3,3
    • Turn the desktop's power supply off.
    • Unplug the desktop from all power sources.
  3. B350M BAZOOKA Motherboard GPU Replacement: 步骤 3 中的图像 1,2 B350M BAZOOKA Motherboard GPU Replacement: 步骤 3 中的图像 2,2
    • Remove the screws on the front of the case.
    • Screw types may vary by desktop case.
    • These screws hold the front panel, which promotes airflow inside the desktop. Do not misplace them.
  4. B350M BAZOOKA Motherboard GPU Replacement: 步骤 4 中的图像 1,2 B350M BAZOOKA Motherboard GPU Replacement: 步骤 4 中的图像 2,2
    • Gently remove the front panel by pulling it away from the case.
  5. B350M BAZOOKA Motherboard GPU Replacement: 步骤 5 中的图像 1,1
    • Place the desktop horizontally, so the motherboard is facing up.
  6. B350M BAZOOKA Motherboard GPU Replacement: 步骤 6 中的图像 1,3 B350M BAZOOKA Motherboard GPU Replacement: 步骤 6 中的图像 2,3 B350M BAZOOKA Motherboard GPU Replacement: 步骤 6 中的图像 3,3
    • Disconnect the 8-pin male cable from the GPU.
  7. B350M BAZOOKA Motherboard GPU Replacement: 步骤 7 中的图像 1,2 B350M BAZOOKA Motherboard GPU Replacement: 步骤 7 中的图像 2,2
    • Remove the UTS 6-32 screws on the side of the desktop using a Phillips #0 screwdriver.
    • These screws hold the GPU display ports in place. Do not misplace them.
  8. B350M BAZOOKA Motherboard GPU Replacement: 步骤 8 中的图像 1,2 B350M BAZOOKA Motherboard GPU Replacement: 步骤 8 中的图像 2,2
    • Gently press down on the right side of the PCI-E tab until there is a click.
    • The click signifies the GPU has been released.
  9. B350M BAZOOKA Motherboard GPU Replacement: 步骤 9 中的图像 1,1
    • Gently pull the GPU out of the PCI-E slot.
  10. B350M BAZOOKA Motherboard GPU Replacement: 步骤 10 中的图像 1,3 B350M BAZOOKA Motherboard GPU Replacement: 步骤 10 中的图像 2,3 B350M BAZOOKA Motherboard GPU Replacement: 步骤 10 中的图像 3,3
    • Line up the pins of the new GPU with the empty PCI-E slot.
    • Gently push the new GPU into the PCI-E slot until the tab clicks.
  11. B350M BAZOOKA Motherboard GPU Replacement: 步骤 11 中的图像 1,3 B350M BAZOOKA Motherboard GPU Replacement: 步骤 11 中的图像 2,3 B350M BAZOOKA Motherboard GPU Replacement: 步骤 11 中的图像 3,3
    • Gently connect the 8-pin male cable from the power supply to the new GPU.
  12. B350M BAZOOKA Motherboard GPU Replacement: 步骤 12 中的图像 1,2 B350M BAZOOKA Motherboard GPU Replacement: 步骤 12 中的图像 2,2
    • Screw the GPU display port UTS 6-32 screws back in using a Phillips #0 screwdriver.
  13. B350M BAZOOKA Motherboard GPU Replacement: 步骤 13 中的图像 1,1
    • Gently place the front panel back on the desktop.
  14. B350M BAZOOKA Motherboard GPU Replacement: 步骤 14 中的图像 1,3 B350M BAZOOKA Motherboard GPU Replacement: 步骤 14 中的图像 2,3 B350M BAZOOKA Motherboard GPU Replacement: 步骤 14 中的图像 3,3
    • Screw in the front panel screws.
  15. B350M BAZOOKA Motherboard GPU Replacement: 步骤 15 中的图像 1,3 B350M BAZOOKA Motherboard GPU Replacement: 步骤 15 中的图像 2,3 B350M BAZOOKA Motherboard GPU Replacement: 步骤 15 中的图像 3,3
    • Plug the desktop back into a power source.
    • Turn the desktop's power supply on.
    • If the fans on the bottom of the GPU are not spinning once the desktop is on, retry this process. Or begin troubleshooting for a defective GPU.
终点
Mason Price
于10/25/22注册
241 声望
撰写一个指南
团队
CSU Los Angeles, Team 2-16, Briggs Fall 2022 CSU Los Angeles, Team 2-16, Briggs Fall 2022 的会员
CSULA-BRIGGS-F22S2G16
1 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 37
过去 30 天: 100
总计 197
