跳转到主内容
B-Flat Clarinet Key Pad Replacement
你所需要的
  1. B-Flat Clarinet Key Pad Replacement, Key Pad: 步骤 1 中的图像 1,1
    • Disassemble the clarinet until you are handling only the joint containing the missing or damaged pad.
    • If the pad is missing completely, skip to step 3.
  2. B-Flat Clarinet Key Pad Replacement: 步骤 2 中的图像 1,1
    • Remove the damaged pad by inserting the screwdriver under the pad and peeling it off the key.
  3. B-Flat Clarinet Key Pad Replacement: 步骤 3 中的图像 1,1
    • Squeeze a dot of super glue into the empty key.
    • Take care to not overfill the key or glue will ooze out and potentially bind the key to the instrument.
  4. B-Flat Clarinet Key Pad Replacement: 步骤 4 中的图像 1,1
    • Quickly insert the new pad into the key, taking care not to smear the glue.
  5. B-Flat Clarinet Key Pad Replacement: 步骤 5 中的图像 1,1
    • Using the screwdriver, press the pad down to secure it to the key
    • Hold the pad for 5 seconds to let the glue harden
  6. B-Flat Clarinet Key Pad Replacement: 步骤 6 中的图像 1,1
    • Place a small piece of paper between the key and the instrument to avoid residual glue binding the key to the instrument
    • Let the instrument sit out for a few minutes to let the glue fully dry
终点
Rachel Strobel
于10/04/17注册
101 声望
撰写一个指南
团队
Michigan Tech, Team S3-G7, Galliah Fall 2017 Michigan Tech, Team S3-G7, Galliah Fall 2017 的会员
MTU-GALLIAH-F17S3G7
1 名成员
创作了1篇指南
一条评论
From my point of view it would be better to disassemble the key and clean it before gluing a new pad. The best glue in these cases is shellac
Roberto Ottaviani - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 12
总计 1,372
