跳转到主内容
Azpen A909 Front and Rear Facing Camera Assembly Replacement
你所需要的
  1. Azpen A909 Front and Rear Facing Camera Assembly Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Begin by unscrewing the two 1.4 mm diameter Phillips #00 head screws at the top of the device.
  2. Azpen A909 Front and Rear Facing Camera Assembly Replacement: 步骤 2 中的图像 1,1
    • Next, gently pry the cover off with a plastic opening tool or a similar instrument by loosening all of the anchoring points. Two of the anchoring points are circled in the image. Avoid excessive bending or pivoting, since doing so may break the anchoring points.
  3. Azpen A909 Front and Rear Facing Camera Assembly Replacement: 步骤 3 中的图像 1,1
    • After prying open all of the anchoring points, the cover will lift off of the tablet.
    • To replace the cover, simply snap it back in place and re-insert the two screws. Because the speaker is not fully fixed to the interior of the tablet, make sure that it is in the position that will allow it to fit inside the speaker mounting on the cover.
  4. Azpen A909 Front and Rear Facing Camera Assembly Replacement, Front and Rear Facing Camera Assembly: 步骤 4 中的图像 1,1
    • Using a plastic opening tool, gently peel back the black electrical tape to reveal the power strip and the front facing camera, which is marked by the red box in the image.
  5. Azpen A909 Front and Rear Facing Camera Assembly Replacement: 步骤 5 中的图像 1,1
    • Gently pull the front facing camera out of its mounting point. Use a spudger if necessary.
  6. Azpen A909 Front and Rear Facing Camera Assembly Replacement: 步骤 6 中的图像 1,1
    • Using the spudger, pry the rear facing camera its power strip off the circuit board. This may require some force, since a strong adhesive is used to mount the camera assembly to that point.
  7. Azpen A909 Front and Rear Facing Camera Assembly Replacement: 步骤 7 中的图像 1,1
    • Lift open the connector flap with the spudger.
  8. Azpen A909 Front and Rear Facing Camera Assembly Replacement: 步骤 8 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • At this point, all points of the camera assembly should be detached from the device.
    • Lift and remove the power strip/camera assembly from the device with a pair of tweezers.
结论
Jordan
于03/15/15注册
381 声望
创作了2篇指南
团队
UMass Dartmouth, Team 3-5, Duarte Spring 2015 UMass Dartmouth, Team 3-5, Duarte Spring 2015 的会员
UMASSD-DUARTE-S15S3G5
3 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 191
