跳转到主内容
加入维修社区 - 创建账户
Azpen A909 Back Cover Replacement
你所需要的
  1. Azpen A909 Back Cover Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Begin by unscrewing the two 1.4 mm diameter Phillips #00 head screws at the top of the device.
  2. Azpen A909 Back Cover Replacement: 步骤 2 中的图像 1,1
    • Next, gently pry the cover off with a plastic opening tool or a similar instrument by loosening all of the anchoring points. Two of the anchoring points are circled in the image. Avoid excessive bending or pivoting, since doing so may break the anchoring points.
  3. Azpen A909 Back Cover Replacement: 步骤 3 中的图像 1,1
    • After prying open all of the anchoring points, the cover will lift off of the tablet.
    • To replace the cover, simply snap it back in place and re-insert the two screws. Because the speaker is not fully fixed to the interior of the tablet, make sure that it is in the position that will allow it to fit inside the speaker mounting on the cover.
结论
Karoly Fodor
于03/15/15注册
475 声望
创作了3篇指南
团队
UMass Dartmouth, Team 3-5, Duarte Spring 2015 UMass Dartmouth, Team 3-5, Duarte Spring 2015 的会员
UMASSD-DUARTE-S15S3G5
3 名成员
创作了12篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 14
总计 586
