简介
The screen assembly is located underneath all of the other parts of the device. To access it, you will have to remove these pieces first. Make sure to keep track of all five screws and any connected parts.
你所需要的
Remove the two 2cm screws on the bottom using the PH0 Phillips head screw driver.
Disconnect the two larger of the three ZIF cables by prying open the flap with a plastic spudger and gently removing the cable.
另外一个人完成了本指南。
