跳转到主内容
加入维修社区 - 创建账户
Azpen A701 General Disassembly Prerequisite Guide Replacement
你所需要的
  1. Azpen A701 General Disassembly Prerequisite Guide Replacement, General Disassembly Prerequisite Guide: 步骤 1 中的图像 1,1
    • Remove the two 2cm screws on the bottom using the PH0 Phillips head screw driver.
  2. Azpen A701 General Disassembly Prerequisite Guide Replacement: 步骤 2 中的图像 1,2 Azpen A701 General Disassembly Prerequisite Guide Replacement: 步骤 2 中的图像 2,2
    • Pry open the back piece with the plastic spudger.
    • Remove the back piece from the device.
    • The back panel may be difficult to pry off, use gentle force.
  3. Azpen A701 General Disassembly Prerequisite Guide Replacement: 步骤 3 中的图像 1,1
    • Disconnect speaker (which is attached by black and red wires) from back piece using plastic spudger.
  4. Azpen A701 General Disassembly Prerequisite Guide Replacement: 步骤 4 中的图像 1,1
    • Gently pry the battery off of the device with the plastic spudger.
    • There is a large amount of glue holding the battery to the device.
    • Do not puncture the battery with the plastic spudger.
结论
另外一个人完成了本指南。
Michael
于03/11/15注册
568 声望
创作了4篇指南
团队
Colorado Springs, Team 2-1, Panko Spring 2015 Colorado Springs, Team 2-1, Panko Spring 2015 的会员
UCCS-PANKO-S15S2G1
3 名成员
创作了12篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 8
总计 483
