跳转到主内容
Axess TA2513-10WT Speaker Replacement
你所需要的
  1. Axess TA2513-10WT Speaker Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Lay the tablet down on a flat surface with the screen facing up, and the external camera facing upwards and closest to you.
  2. Axess TA2513-10WT Speaker Replacement: 步骤 2 中的图像 1,3 Axess TA2513-10WT Speaker Replacement: 步骤 2 中的图像 2,3 Axess TA2513-10WT Speaker Replacement: 步骤 2 中的图像 3,3
    • Insert the plastic opening tool in the space between the screen and the back cover above the volume buttons.
    • Slide the plastic opening tool gently along the sides.
    • If a small gap is not created between the screen and the back cover, pry gently upward at each of these latching points.
  3. Axess TA2513-10WT Speaker Replacement: 步骤 3 中的图像 1,1
    • Place the spudger in an open space to keep the back case from shutting while you continue to slide the opening tool.
  4. Axess TA2513-10WT Speaker Replacement: 步骤 4 中的图像 1,1
    • Remove the back cover with your hands once all points have been unlatched. It should separate completely from the screen that contains the battery and chip components.
  5. Axess TA2513-10WT Speaker Replacement, Speaker: 步骤 5 中的图像 1,1
    • Remove tape attached to black and red speaker wires.
  6. Axess TA2513-10WT Speaker Replacement: 步骤 6 中的图像 1,1
    • Identify the four speaker nodes.
    • From left to right the nodes are "SPKP1", "SPKN1", "LN", and "LP"
  7. Axess TA2513-10WT Speaker Replacement: 步骤 7 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Place the soldering tool on the speaker node labeled "SPKP1" and quickly remove the red wire with tweezers.
  8. Axess TA2513-10WT Speaker Replacement: 步骤 8 中的图像 1,1
    • Place the soldering tool on the speaker node labeled "SPKN1" and quickly remove the black wire with tweezers.
  9. Axess TA2513-10WT Speaker Replacement: 步骤 9 中的图像 1,1
    • Place the soldering tool on the speaker node labeled "LP" and quickly remove the black wire with the tweezers.
  10. Axess TA2513-10WT Speaker Replacement: 步骤 10 中的图像 1,1
    • Place the soldering tool on the speaker node labeled "LN" and quickly remove the red wire with tweezers.
结论
Steven Kavanagh
于03/24/15注册
301 声望
创作了3篇指南
团队
Baylor, Team 6-3, Shaver Spring 2015 Baylor, Team 6-3, Shaver Spring 2015 的会员
BU-SHAVER-S15S6G3
3 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 8
总计 320
