跳转到主内容
Axess TA2513-10WT Side Button Replacement
你所需要的
  1. Axess TA2513-10WT Side Button Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Lay the tablet down on a flat surface with the screen facing up, and the external camera facing upwards and closest to you.
  2. Axess TA2513-10WT Side Button Replacement: 步骤 2 中的图像 1,3 Axess TA2513-10WT Side Button Replacement: 步骤 2 中的图像 2,3 Axess TA2513-10WT Side Button Replacement: 步骤 2 中的图像 3,3
    • Insert the plastic opening tool in the space between the screen and the back cover above the volume buttons.
    • Slide the plastic opening tool gently along the sides.
    • If a small gap is not created between the screen and the back cover, pry gently upward at each of these latching points.
  3. Axess TA2513-10WT Side Button Replacement: 步骤 3 中的图像 1,1
    • Place the spudger in an open space to keep the back case from shutting while you continue to slide the opening tool.
  4. Axess TA2513-10WT Side Button Replacement: 步骤 4 中的图像 1,1
    • Remove the back cover with your hands once all points have been unlatched. It should separate completely from the screen that contains the battery and chip components.
  5. Axess TA2513-10WT Side Button Replacement, Buttons: 步骤 5 中的图像 1,2 Axess TA2513-10WT Side Button Replacement, Buttons: 步骤 5 中的图像 2,2
    • Orient the tablet's back cover so that the inside faces up and the buttons are positioned at the top left corner.
  6. Axess TA2513-10WT Side Button Replacement: 步骤 6 中的图像 1,2 Axess TA2513-10WT Side Button Replacement: 步骤 6 中的图像 2,2
    • Unlatch the clear rubber holder from the posts with the tweezers.
  7. Axess TA2513-10WT Side Button Replacement: 步骤 7 中的图像 1,2 Axess TA2513-10WT Side Button Replacement: 步骤 7 中的图像 2,2
    • With tweezers, pull the rubber holder from the back cover completely.
  8. Axess TA2513-10WT Side Button Replacement: 步骤 8 中的图像 1,3 Axess TA2513-10WT Side Button Replacement: 步骤 8 中的图像 2,3 Axess TA2513-10WT Side Button Replacement: 步骤 8 中的图像 3,3
    • Remove the individual buttons with tweezers.
结论
Lori Scott
于03/24/15注册
101 声望
撰写一个指南
团队
Baylor, Team 6-3, Shaver Spring 2015 Baylor, Team 6-3, Shaver Spring 2015 的会员
BU-SHAVER-S15S6G3
3 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 221
