跳转到主内容
Axess TA2513-10WT Back Cover Replacement
你所需要的
  1. Axess TA2513-10WT Back Cover Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Lay the tablet down on a flat surface with the screen facing up, and the external camera facing upwards and closest to you.
  2. Axess TA2513-10WT Back Cover Replacement: 步骤 2 中的图像 1,3 Axess TA2513-10WT Back Cover Replacement: 步骤 2 中的图像 2,3 Axess TA2513-10WT Back Cover Replacement: 步骤 2 中的图像 3,3
    • Insert the plastic opening tool in the space between the screen and the back cover above the volume buttons.
    • Slide the plastic opening tool gently along the sides.
    • If a small gap is not created between the screen and the back cover, pry gently upward at each of these latching points.
  3. Axess TA2513-10WT Back Cover Replacement: 步骤 3 中的图像 1,1
    • Place the spudger in an open space to keep the back case from shutting while you continue to slide the opening tool.
  4. Axess TA2513-10WT Back Cover Replacement: 步骤 4 中的图像 1,1
    • Remove the back cover with your hands once all points have been unlatched. It should separate completely from the screen that contains the battery and chip components.
结论
另外一个人完成了本指南。
Hayley Rabe
于03/24/15注册
125 声望
撰写一个指南
团队
Baylor, Team 6-3, Shaver Spring 2015 Baylor, Team 6-3, Shaver Spring 2015 的会员
BU-SHAVER-S15S6G3
3 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 11
总计 254
