跳转到主内容
Axess SPBT1031 Speaker (Horns) Replacement
你所需要的
  1. Axess SPBT1031 Speaker (Horns) Replacement, Black Faceplate: 步骤 1 中的图像 1,1
    • Look at the side of the speaker that has the red interface plate. Using a Phillips head PH1 screwdriver head, remove screws on the top and bottom of the black face plate. There will be one screw on top and one on the bottom.
    • Both screws are 0.55 cm in depth
  2. Axess SPBT1031 Speaker (Horns) Replacement: 步骤 2 中的图像 1,1
    • Separate the black face plate from the tube by pulling them apart.
    • Be careful when pulling the wires apart or it will potentially damage the wires due to over stretching.
  3. Axess SPBT1031 Speaker (Horns) Replacement, Speaker (Horns): 步骤 3 中的图像 1,1
    • By this point you should have determined which speaker needs to be replaced, to figure this out please refer back to the troubleshooting guide.
    • For the top horn replacement, you will be working with the blue and white wire pair.
    • For the bottom horn replacement you with the yellow and white wire pair.
  4. Axess SPBT1031 Speaker (Horns) Replacement: 步骤 4 中的图像 1,2 Axess SPBT1031 Speaker (Horns) Replacement: 步骤 4 中的图像 2,2
    • To remove the plastic coating around the desired horn, look on the back of the black face plate you removed and use the philips head ph1 screwdriver fitting to remove the two 0.3 cm Philips Head screw and washer combos on the left and right of the horn.
    • Screw depth of 0.7 cm
  5. Axess SPBT1031 Speaker (Horns) Replacement: 步骤 5 中的图像 1,1
    • Lift the horn from its fitting by pulling it. Position it in a manner that is easy to work with.
  6. Axess SPBT1031 Speaker (Horns) Replacement: 步骤 6 中的图像 1,2 Axess SPBT1031 Speaker (Horns) Replacement: 步骤 6 中的图像 2,2
    在这个步骤中使用的工具:
    Desoldering Pump
    $3.99
    购买
    • Use a soldering iron to heat the two contact points.
    • Then use a desoldering pump to remove the liquid solder.
  7. Axess SPBT1031 Speaker (Horns) Replacement: 步骤 7 中的图像 1,1
    • Remove the wires--blue or yellow wire depending on the horn you are replacing--from the old speaker and remove the speaker from the fitting location.
    • For the bottom horn replacement, you will be working with the yellow and white wire pair.
结论
3等其他人完成本指南。
团队
UMass Dartmouth, Team 8-6, Botvin Spring 2016 UMass Dartmouth, Team 8-6, Botvin Spring 2016 的会员
UMASSD-BOTVIN-S16S8G6
3 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 10
总计 1,812
