跳转到主内容
Axe Empire 2.0 OLED Board Replacement
你所需要的
  1. Axe Empire 2.0 OLED Board Replacement, OLED Board: 步骤 1 中的图像 1,2 Axe Empire 2.0 OLED Board Replacement, OLED Board: 步骤 1 中的图像 2,2
    • Use an Allen key to remove four total screws.
    • 2.5 mm screws.
    • 1.2 mm screw.
  2. Axe Empire 2.0 OLED Board Replacement: 步骤 2 中的图像 1,3 Axe Empire 2.0 OLED Board Replacement: 步骤 2 中的图像 2,3 Axe Empire 2.0 OLED Board Replacement: 步骤 2 中的图像 3,3
    • Press and hold the release button while lightly pulling the spring bolt out.
    • If the spring bolt has not been serviced with lube after a long time you might need to pull harder. This is a great time to lube the spring bolt.
  3. Axe Empire 2.0 OLED Board Replacement: 步骤 3 中的图像 1,3 Axe Empire 2.0 OLED Board Replacement: 步骤 3 中的图像 2,3 Axe Empire 2.0 OLED Board Replacement: 步骤 3 中的图像 3,3
    • Remove the two main screws using a 2.5 mm Allen key to separate the air transfer plate from the frame.
  4. Axe Empire 2.0 OLED Board Replacement: 步骤 4 中的图像 1,2 Axe Empire 2.0 OLED Board Replacement: 步骤 4 中的图像 2,2
    • Remove the screw using a 2.5 mm Allen key and remove the foregrip from the frame.
  5. Axe Empire 2.0 OLED Board Replacement: 步骤 5 中的图像 1,2 Axe Empire 2.0 OLED Board Replacement: 步骤 5 中的图像 2,2
    • Use a 1.2 mm Allen key to remove the screw, and remove the cover to expose the OLED Board.
  6. Axe Empire 2.0 OLED Board Replacement: 步骤 6 中的图像 1,3 Axe Empire 2.0 OLED Board Replacement: 步骤 6 中的图像 2,3 Axe Empire 2.0 OLED Board Replacement: 步骤 6 中的图像 3,3
    • Remove the last screw with a 2.5 mm Allen key to loosen the OLED Board.
    • Use a pick tool to carefully remove the battery and OLED Board together out of the foregrip.
    • Wear gloves in case battery is defective and leaking acid.
  7. Axe Empire 2.0 OLED Board Replacement: 步骤 7 中的图像 1,2 Axe Empire 2.0 OLED Board Replacement: 步骤 7 中的图像 2,2
    • Disconnect the battery from the OLED board.
结论
Christopher Ramos
于10/05/21注册
345 声望
撰写一个指南
团队
CSU Los Angeles, Team 11-2, Grodsky Fall 2021 CSU Los Angeles, Team 11-2, Grodsky Fall 2021 的会员
CSULA-GRODSKY-F21S11G2
1 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 7
总计 191
