1. To enable manual mode, flip the switch to "Business as usual" LCD screen will turn on
    • To enable manual mode, flip the switch to "Business as usual"
    • LCD screen will turn on
  2. Press Stop Press Start Sampling Press Enter
    • Press Stop
    • Press Start Sampling
    • Press Enter
  3. 所有超过US$100或包含 Pro Tech工具包的订单免费送货!
    浏览我们的商店
  4. Enter in the bottle you would like to start sampling at Press Enter LCD should now show which bottle it will take a sample in
    • Enter in the bottle you would like to start sampling at
    • Press Enter
    • LCD should now show which bottle it will take a sample in
  5. To enable autonomous mode, flip switch to "Shut up and take my samples" LCD should turn off If the autosampler is to be remotely triggered, avoid using the ON/OFF button to power off the sampler.
    • To enable autonomous mode, flip switch to "Shut up and take my samples"
    • LCD should turn off
    • If the autosampler is to be remotely triggered, avoid using the ON/OFF button to power off the sampler.
结论
Now the sampler is ready to be triggered remotely by an open-storm sensor node.
Brandon Wong
于2018年01月16日注册
429 信誉积分
创作了2篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 4
总计 208
