跳转到主内容
Autosampler Reset for Node Triggered Sampling (For Old & New Versions)
  1. Autosampler Reset for Node Triggered Sampling  (For Old & New Versions), Switch to manual mode: 步骤 1 中的图像 1,2 Autosampler Reset for Node Triggered Sampling  (For Old & New Versions), Switch to manual mode: 步骤 1 中的图像 2,2
    • To enable manual mode, flip the switch to "Manual Mode"
    • LCD screen will turn on
  2. Autosampler Reset for Node Triggered Sampling  (For Old & New Versions), Restart the sampling program: 步骤 2 中的图像 1,2 Autosampler Reset for Node Triggered Sampling  (For Old & New Versions), Restart the sampling program: 步骤 2 中的图像 2,2
    • Press On then press Start Sampling
    • Press Enter
  3. Autosampler Reset for Node Triggered Sampling  (For Old & New Versions), Select bottle: 步骤 3 中的图像 1,3 Autosampler Reset for Node Triggered Sampling  (For Old & New Versions), Select bottle: 步骤 3 中的图像 2,3 Autosampler Reset for Node Triggered Sampling  (For Old & New Versions), Select bottle: 步骤 3 中的图像 3,3
    • Press the number of the bottle you want to sample on
    • Press Enter
    • LCD should now show which bottle it will take a sample in
  4. Autosampler Reset for Node Triggered Sampling  (For Old & New Versions), Switch to autonomous mode: 步骤 4 中的图像 1,2 Autosampler Reset for Node Triggered Sampling  (For Old & New Versions), Switch to autonomous mode: 步骤 4 中的图像 2,2
    • To enable autonomous mode, flip switch to "Node Trigger Mode"
    • LCD should turn off
    • If the autosampler is to be remotely triggered, avoid using the ON/OFF button to power off the sampler.
结论
Now the sampler is ready to be triggered remotely by an open-storm sensor node.
另外一个人完成了本指南。
Brandon Wong
于01/16/18注册
502 声望
创作了2篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 383
