跳转到主内容
加入维修社区 - 创建账户
Autosampler Deployment (2021)
你所需要的
  1. Autosampler Deployment (2021), Assemble the Sampler: 步骤 1 中的图像 1,3 Autosampler Deployment (2021), Assemble the Sampler: 步骤 1 中的图像 2,3 Autosampler Deployment (2021), Assemble the Sampler: 步骤 1 中的图像 3,3
    • Ensure that the batteries are plugged in inside the boxes before assembly and that the node box is on manual mode (noted as manual mode or sampling normally on the battery box).
    • Fit the node box under the sampler lid on the side of the programmer next to the tubing outlet.
    • Fit the battery box behind the sampler.
    • Screw the battery terminal and the flow terminal into the sampler.
    • Wrap and tuck the wires on the unused side of the sampler and secure with tape and twist ties.
  2. Autosampler Deployment (2021), Feed Tubing up to Water: 步骤 2 中的图像 1,3 Autosampler Deployment (2021), Feed Tubing up to Water: 步骤 2 中的图像 2,3 Autosampler Deployment (2021), Feed Tubing up to Water: 步骤 2 中的图像 3,3
    • Push the vinyl tubing into the pump nozzle on the sampler.
    • Feed the tubing through the woods and secure it so that it will not move throughout a storm
    • Small increases in elevation are okay, but it is ideal for the tubing to have a downward slope at all times.
  3. Autosampler Deployment (2021), Attach Tubing to Sontek Sensor: 步骤 3 中的图像 1,3 Autosampler Deployment (2021), Attach Tubing to Sontek Sensor: 步骤 3 中的图像 2,3 Autosampler Deployment (2021), Attach Tubing to Sontek Sensor: 步骤 3 中的图像 3,3
    • Extend the tubing through the water to reach the Sontek Sensor.
    • Attach the tubing to the steel strut channel using a band clamp, and compress it until the tubing is secure but open.
    • Do not compress the tube too much because it can make the sampler work too hard.
    • Bring the tubing to the bottom of the stream bed by covering it in rocks without compressing the tubing so much that water could not pump through.
    • Could also potentially secure it down with hardware to the stream bed.
  4. Autosampler Deployment (2021), Connect Battery Box and Node Box: 步骤 4 中的图像 1,3 Autosampler Deployment (2021), Connect Battery Box and Node Box: 步骤 4 中的图像 2,3 Autosampler Deployment (2021), Connect Battery Box and Node Box: 步骤 4 中的图像 3,3
    • Connect the male and female crimp connectors from the battery box and node box respectively.
    • Connect the male and female amphenol battery connectors from the battery box and node box respectively.
    • Secure loose wire to the sampler with tape on the opposite side of the sampler as the node box.
  5. Autosampler Deployment (2021), Program the Sampler: 步骤 5 中的图像 1,1
    • Program the sampler based upon the settings outlined in the Autosampler Programming and Autosampler Configuration guides.
    • Alter the line length and similar parameters as they differ in the field from the guides.
  6. Autosampler Deployment (2021), Close the Sampler: 步骤 6 中的图像 1,2 Autosampler Deployment (2021), Close the Sampler: 步骤 6 中的图像 2,2
    • Switch the box to node mode (marked as node mode or "shut up and take my samples" on the box), and put the lid on the sampler.
    • Attach the 3 carabiners to the hooks on the sampler, and connect them at the top in a lock.
    • Wait until the first sample is triggered and taken from the cloud to confirm that the sampler is connected and taking the correct volume.
终点
另外一个人完成了本指南。
Gina Kittleson
于05/19/21注册
493 声望
创作了3篇指南
团队
Open-Storm Open-Storm 的会员
Community
14 名成员
创作了24篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 7
总计 144
