跳转到主内容
Automatic Tommy 20 Ammo Drum Replacement
你所需要的
  1. Automatic Tommy 20 Ammo Drum Replacement, Splitting the Gun into Two Halves: 步骤 1 中的图像 1,2 Automatic Tommy 20 Ammo Drum Replacement, Splitting the Gun into Two Halves: 步骤 1 中的图像 2,2
    • Locate the orange slider on the front side of the gun.
    • Pull the orange slider towards the back of the gun while lifting up on the nose the gun.
  2. Automatic Tommy 20 Ammo Drum Replacement: 步骤 2 中的图像 1,3 Automatic Tommy 20 Ammo Drum Replacement: 步骤 2 中的图像 2,3 Automatic Tommy 20 Ammo Drum Replacement: 步骤 2 中的图像 3,3
    • Remove the single 1/8 in. screw at the junction of the body and the nose using a Philips #00 Screwdriver.
    • Remove all parts within the chamber to be able to completely detach the nose of the gun.
    • Be careful to keep track of all the components for reassembly.
  3. Automatic Tommy 20 Ammo Drum Replacement, Ammo Drum: 步骤 3 中的图像 1,3 Automatic Tommy 20 Ammo Drum Replacement, Ammo Drum: 步骤 3 中的图像 2,3 Automatic Tommy 20 Ammo Drum Replacement, Ammo Drum: 步骤 3 中的图像 3,3
    • Remove the 1/16 in. screws using a Phillips #00 Screwdriver as indicated in the photo on the left.
    • Remove the 1 mm screw on the battery lid using a Philips #1 Screwdriver as indicated in the photo on the left.
  4. Automatic Tommy 20 Ammo Drum Replacement: 步骤 4 中的图像 1,1
    • Carefully spread apart the two halves of the gun, and lift out the ammo drum.
结论
3等其他人完成本指南。
Moira Foster
于10/09/14注册
419 声望
创作了3篇指南
团队
Cal Poly, Team 6-22, Maness Fall 2014 Cal Poly, Team 6-22, Maness Fall 2014 的会员
CPSU-MANESS-F14S6G22
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 10
总计 764
