跳转到主内容
Automatic Tommy 20 Ammo Drum Bushing Replacement
你所需要的
  1. Automatic Tommy 20 Ammo Drum Bushing Replacement, Splitting the Gun into Two Halves: 步骤 1 中的图像 1,2 Automatic Tommy 20 Ammo Drum Bushing Replacement, Splitting the Gun into Two Halves: 步骤 1 中的图像 2,2
    • Locate the orange slider on the front side of the gun.
    • Pull the orange slider towards the back of the gun while lifting up on the nose the gun.
  2. Automatic Tommy 20 Ammo Drum Bushing Replacement: 步骤 2 中的图像 1,3 Automatic Tommy 20 Ammo Drum Bushing Replacement: 步骤 2 中的图像 2,3 Automatic Tommy 20 Ammo Drum Bushing Replacement: 步骤 2 中的图像 3,3
    • Remove the single 1/8 in. screw at the junction of the body and the nose using a Philips #00 Screwdriver.
    • Remove all parts within the chamber to be able to completely detach the nose of the gun.
    • Be careful to keep track of all the components for reassembly.
  3. Automatic Tommy 20 Ammo Drum Bushing Replacement, Disassembling the Nose of the Gun: 步骤 3 中的图像 1,3 Automatic Tommy 20 Ammo Drum Bushing Replacement, Disassembling the Nose of the Gun: 步骤 3 中的图像 2,3 Automatic Tommy 20 Ammo Drum Bushing Replacement, Disassembling the Nose of the Gun: 步骤 3 中的图像 3,3
    • Remove all five 1/16 in. screws holding the nose of the gun together using a Phillips #00 screwdriver.
    • Look out for the hidden fifth screw behind the thin light green tape near the bushing itself. Peel the tape using your finger to gain access.
  4. Automatic Tommy 20 Ammo Drum Bushing Replacement, Removing the Bushing: 步骤 4 中的图像 1,1
    • Pick up the now split half of the nose of the gun that does not still have the orange tip attached to it.
    • Remove the bushing by simply pulling it away from the plastic.
结论
另外一个人完成了本指南。
Moira Foster
于10/09/14注册
419 声望
创作了3篇指南
团队
Cal Poly, Team 6-22, Maness Fall 2014 Cal Poly, Team 6-22, Maness Fall 2014 的会员
CPSU-MANESS-F14S6G22
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 1,355
