跳转到主内容
Auking M8-F PCB Button Panel Replacement
你所需要的
  1. Auking M8-F PCB Button Panel Replacement, PCB Button Panel: 步骤 1 中的图像 1,2 Auking M8-F PCB Button Panel Replacement, PCB Button Panel: 步骤 1 中的图像 2,2
    • Make sure that the device is unplugged from any power source before attempting any repairs.
    • Flip the projector on its opposite side.
    • Remove all six of the 11 mm screws using a Phillips #1 screwdriver.
    • Remove the two 14 mm screws using a Phillips #1 screwdriver.
  2. Auking M8-F PCB Button Panel Replacement: 步骤 2 中的图像 1,2 Auking M8-F PCB Button Panel Replacement: 步骤 2 中的图像 2,2
    • Carefully prop open the top of the projector.
    • Disconnect the cable attached to the top lid.
    • Remove the top lid.
  3. Auking M8-F PCB Button Panel Replacement: 步骤 3 中的图像 1,2 Auking M8-F PCB Button Panel Replacement: 步骤 3 中的图像 2,2
    • Remove the wire cord attached to the top panel to separate both the top panel and the wire cord.
  4. Auking M8-F PCB Button Panel Replacement: 步骤 4 中的图像 1,3 Auking M8-F PCB Button Panel Replacement: 步骤 4 中的图像 2,3 Auking M8-F PCB Button Panel Replacement: 步骤 4 中的图像 3,3
    • Remove six of the 5 mm screws using a Phillips #00 screwdriver to detach the power panel.
    • Remove the power panel.
结论
Aubrey Haynes
于09/13/23注册
286 声望
创作了3篇指南
1指南评论
I have a problem not covered here.
When I power up, only a red light is lit. Any ideas?
sasquachnw@duck.com
sasquachnw - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 9
总计 209
