跳转到主内容
Audiovox CR8030iE5 Top-Casing Replacement
你所需要的
  1. Audiovox CR8030iE5 Top-Casing Replacement, Top-Casing: 步骤 1 中的图像 1,1
    • Turn the device upside down.
    • Apply constant pressure to the base of your Audiovox, while holding the plastic casing until the casing is completely removed.
  2. Audiovox CR8030iE5 Top-Casing Replacement: 步骤 2 中的图像 1,1
    • Remove the four screws from the base using a Phillips #1 screwdriver.
  3. Audiovox CR8030iE5 Top-Casing Replacement: 步骤 3 中的图像 1,1
    • Turn the device right-side up.
    • Gently pull the top panel off of the device.
  4. Audiovox CR8030iE5 Top-Casing Replacement: 步骤 4 中的图像 1,1
    • Using a Phillips #1 screwdriver, remove the screw found in the middle of the board.
  5. Audiovox CR8030iE5 Top-Casing Replacement: 步骤 5 中的图像 1,1
    • Pull back the board gently to avoid disconnecting the attached wires.
    • This allows you to view the soldered connections on the other side, and the internal components.
结论
Savannah Smith
于04/18/13注册
51 声望
创作了2篇指南
团队
Cal Poly, Team 10-39, Amido Spring 2013 Cal Poly, Team 10-39, Amido Spring 2013 的会员
CPSU-AMIDO-S13S10G39
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 356
