跳转到主内容
Audiovox CR8030iE5 Docking Port Replacement
你所需要的
  1. Audiovox CR8030iE5 Docking Port Replacement, Top-Casing: 步骤 1 中的图像 1,1
    • Turn the device upside down.
    • Apply constant pressure to the base of your Audiovox, while holding the plastic casing until the casing is completely removed.
  2. Audiovox CR8030iE5 Docking Port Replacement: 步骤 2 中的图像 1,1
    • Remove the four screws from the base using a Phillips #1 screwdriver.
  3. Audiovox CR8030iE5 Docking Port Replacement: 步骤 3 中的图像 1,1
    • Turn the device right-side up.
    • Gently pull the top panel off of the device.
  4. Audiovox CR8030iE5 Docking Port Replacement: 步骤 4 中的图像 1,1
    • Using a Phillips #1 screwdriver, remove the screw found in the middle of the board.
  5. Audiovox CR8030iE5 Docking Port Replacement: 步骤 5 中的图像 1,1
    • Pull back the board gently to avoid disconnecting the attached wires.
    • This allows you to view the soldered connections on the other side, and the internal components.
  6. Audiovox CR8030iE5 Docking Port Replacement, Docking Port: 步骤 6 中的图像 1,1
    • One by one, de-solder the line of nine wires attached to the docking port board. After pulling out the wires, save them. This is done so that you can solder them into the new docking port board.
    • If you don't know how to solder, check out 如何焊接和拆焊.
    • Soldering irons are extremely hot and can burn you if you touch them!
    • If you hold the soldering iron tip at the same spot for too long, it can strip the metal from the plastic board. You may not be able to solder wire to that point again.
  7. Audiovox CR8030iE5 Docking Port Replacement: 步骤 7 中的图像 1,1
    • Carefully insert the wires into the designated holes on the new docking port board and solder them into place.
结论
另外一个人完成了本指南。
Nab Sengupta
于04/18/13注册
55 声望
创作了4篇指南
团队
Cal Poly, Team 10-39, Amido Spring 2013 Cal Poly, Team 10-39, Amido Spring 2013 的会员
CPSU-AMIDO-S13S10G39
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 345
