跳转到主内容
Audiovox CDM-8910 Rear Case Replacement
你所需要的
  1. Audiovox CDM-8910 Rear Case Replacement, Antenna: 步骤 1 中的图像 1,1
    • Locate the antenna (shown in red box) at the top of the phone when closed.
  2. Audiovox CDM-8910 Rear Case Replacement: 步骤 2 中的图像 1,1
    • Using your thumb and index finger, grip the antenna near its base and unscrew counter clockwise. Once loose, remove the antenna by pulling it from its insert hole.
  3. Audiovox CDM-8910 Rear Case Replacement, Battery: 步骤 3 中的图像 1,1
    • Locate the back side of the phone.
    • The battery is the large main compartment (red box).
  4. Audiovox CDM-8910 Rear Case Replacement: 步骤 4 中的图像 1,1
    • Use your finger to slide the latch (circled) upwards.
    • While holding the latch up, pull the battery off the phone.
  5. Audiovox CDM-8910 Rear Case Replacement: 步骤 5 中的图像 1,1
    • The back of the phone will look like this when the battery is correctly removed.
  6. Audiovox CDM-8910 Rear Case Replacement, Rear Case: 步骤 6 中的图像 1,1
    • Peel the rubber indicated toward the top of the phone
  7. Audiovox CDM-8910 Rear Case Replacement: 步骤 7 中的图像 1,1
    • Remove the screw that sits underneath the rubber covering.
  8. Audiovox CDM-8910 Rear Case Replacement: 步骤 8 中的图像 1,1
    • Remove the five (5) total screws using a Philips head screwdriver.
  9. Audiovox CDM-8910 Rear Case Replacement: 步骤 9 中的图像 1,1
    • Use spudger and insert it towards the bottom of the phone as pictured.
    • Carefully working yourself around the phone with the spudger, pry it open. This may require a bit of force.
    • The volume control button will be loose, so make sure to take it out once the rear case is fully removed.
  10. Audiovox CDM-8910 Rear Case Replacement: 步骤 10 中的图像 1,1
    • The back case should now be completely removed and the motherboard will be visible.
结论
Carlos Guerrero
于10/04/10注册
1 声望
创作了2篇指南
团队
Cal Poly, Team 3-24, Regan Fall 2010 Cal Poly, Team 3-24, Regan Fall 2010 的会员
CPSU-REGAN-F10S3G24
4 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 1,679
