跳转到主内容
Audiovox CDM-8910 Motherboard Replacement
你所需要的
  1. Audiovox CDM-8910 Motherboard Replacement, Battery: 步骤 1 中的图像 1,1
    • Locate the back side of the phone.
    • The battery is the large main compartment (red box).
  2. Audiovox CDM-8910 Motherboard Replacement: 步骤 2 中的图像 1,1
    • Use your finger to slide the latch (circled) upwards.
    • While holding the latch up, pull the battery off the phone.
  3. Audiovox CDM-8910 Motherboard Replacement: 步骤 3 中的图像 1,1
    • The back of the phone will look like this when the battery is correctly removed.
  4. Audiovox CDM-8910 Motherboard Replacement, Rear Case: 步骤 4 中的图像 1,1
    • Peel the rubber indicated toward the top of the phone
  5. Audiovox CDM-8910 Motherboard Replacement: 步骤 5 中的图像 1,1
    • Remove the screw that sits underneath the rubber covering.
  6. Audiovox CDM-8910 Motherboard Replacement: 步骤 6 中的图像 1,1
    • Remove the five (5) total screws using a Philips head screwdriver.
  7. Audiovox CDM-8910 Motherboard Replacement: 步骤 7 中的图像 1,1
    • Use spudger and insert it towards the bottom of the phone as pictured.
    • Carefully working yourself around the phone with the spudger, pry it open. This may require a bit of force.
    • The volume control button will be loose, so make sure to take it out once the rear case is fully removed.
  8. Audiovox CDM-8910 Motherboard Replacement: 步骤 8 中的图像 1,1
    • The back case should now be completely removed and the motherboard will be visible.
  9. Audiovox CDM-8910 Motherboard Replacement, Motherboard: 步骤 9 中的图像 1,3 Audiovox CDM-8910 Motherboard Replacement, Motherboard: 步骤 9 中的图像 2,3 Audiovox CDM-8910 Motherboard Replacement, Motherboard: 步骤 9 中的图像 3,3
    • Disconnect the gold connection patch
    • Use a spudger or finger to disconnect the piece.
  10. Audiovox CDM-8910 Motherboard Replacement: 步骤 10 中的图像 1,1
    • Using a spudger, lift the motherboard out of the phone case as pictured.
  11. Audiovox CDM-8910 Motherboard Replacement: 步骤 11 中的图像 1,1
    • The motherboard should now be completely removed from the phone.
结论
Sean Green
于10/04/10注册
29 声望
创作了2篇指南
团队
Cal Poly, Team 3-24, Regan Fall 2010 Cal Poly, Team 3-24, Regan Fall 2010 的会员
CPSU-REGAN-F10S3G24
4 名成员
创作了12篇指南
一条评论
Where on this phone’s motherboard is the memory card located? I’d like to try and remove mine to download the data from it.
Ernie Freeman - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 10
过去 30 天: 16
总计 2,227
