当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
With phone in the flipped-open position, use a spudger to remove the four (4) rubber pads (one shown in red circle) located near the corners of the face with the LCD screen.
Use a small Phillips head screwdriver to remove the four (4) screws exposed by removed rubber pads.
Use a spudger to pry the front cover off of the phone, gradually working your way around the front face.
Use a spudger to lift away and remove the metallic frame (in blue).
Use the spudger to lift away the two electrical contacts (in red).
Use the spudger to lift away the speaker (in yellow).
This is what the rear of the LCD screen should look like before proceeding. Note all necessary connections are undone.
Use a spudger to lift away the LCD screen.
LCD screen successfully removed!
取消:我没有完成这个指南。
另外一个人完成了本指南。
与4其他贡献者
于10/04/10注册
11 声望
创作了2篇指南
徽章: 4
+1个徽章
CPSU-REGAN-F10S3G24
4 名成员
创作了12篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 3
过去 7 天: 11
过去 30 天: 15
总计 2,907
