跳转到主内容
Audiovox CDM-8900 Motherboard Replacement
你所需要的
  1. Audiovox CDM-8900 Motherboard Replacement, Battery: 步骤 1 中的图像 1,2 Audiovox CDM-8900 Motherboard Replacement, Battery: 步骤 1 中的图像 2,2
    • Hold the phone in one hand, slide the latch up, and pull the battery up to remove it.
  2. Audiovox CDM-8900 Motherboard Replacement, Antenna: 步骤 2 中的图像 1,3 Audiovox CDM-8900 Motherboard Replacement, Antenna: 步骤 2 中的图像 2,3 Audiovox CDM-8900 Motherboard Replacement, Antenna: 步骤 2 中的图像 3,3
    • Grasp the antenna at its base and twist to unscrew.
    • Remove the antenna along with its plastic casing from inside the battery housing. Keep the antenna in the plastic casing for reassembly.
  3. Audiovox CDM-8900 Motherboard Replacement, Motherboard: 步骤 3 中的图像 1,3 Audiovox CDM-8900 Motherboard Replacement, Motherboard: 步骤 3 中的图像 2,3 Audiovox CDM-8900 Motherboard Replacement, Motherboard: 步骤 3 中的图像 3,3
    • Remove the small rubber insert from the top of the phone to access the top screw.
    • Unscrew all five screws on the back of the cell phone with a Phillips #00 screwdriver.
    • If screws do not slide out after unscrewing, gently flip and tap the phone in your hand until the screws come loose.
  4. Audiovox CDM-8900 Motherboard Replacement: 步骤 4 中的图像 1,3 Audiovox CDM-8900 Motherboard Replacement: 步骤 4 中的图像 2,3 Audiovox CDM-8900 Motherboard Replacement: 步骤 4 中的图像 3,3
    • Wedge the phone plate toward you, using the leverage from an opening tool.
    • The volume control button on the left side of the phone will loosen. Make sure to carefully reinsert it during reassembly.
    • Detach the motherboard from the LCD screen connector by gently detaching the small copper plate on the top right of the motherboard.
  5. Audiovox CDM-8900 Motherboard Replacement: 步骤 5 中的图像 1,3 Audiovox CDM-8900 Motherboard Replacement: 步骤 5 中的图像 2,3 Audiovox CDM-8900 Motherboard Replacement: 步骤 5 中的图像 3,3
    • To release the motherboard, push the large "OK" button located on the other side of the phone.
    • Before reassembly, make sure the keypad is lined up with the motherboard. Be sure the camera lens is properly aligned at the top of the motherboard and the volume controls are in place.
结论
另外一个人完成了本指南。
Aaron Shaw
于04/15/10注册
159 声望
创作了6篇指南
团队
Cal Poly, Team 28-31, Regan Spring 2010 Cal Poly, Team 28-31, Regan Spring 2010 的会员
CPSU-REGAN-S10S28G31
4 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 13
总计 2,810
