跳转到主内容
Audiovox CDM-8900 Main LCD Screen Replacement
你所需要的
  1. Audiovox CDM-8900 Main LCD Screen Replacement, Main LCD Screen: 步骤 1 中的图像 1,2 Audiovox CDM-8900 Main LCD Screen Replacement, Main LCD Screen: 步骤 1 中的图像 2,2
    • Remove four screw covers using the spudger.
    • Because the bottom two screw covers are attached with an adhesive, you will not be able to replace them when you reassemble the phone.
  2. Audiovox CDM-8900 Main LCD Screen Replacement: 步骤 2 中的图像 1,2 Audiovox CDM-8900 Main LCD Screen Replacement: 步骤 2 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Remove the four Phillips #00 screws.
    • Tweezers may be useful for removing loosened screws.
  3. Audiovox CDM-8900 Main LCD Screen Replacement: 步骤 3 中的图像 1,3 Audiovox CDM-8900 Main LCD Screen Replacement: 步骤 3 中的图像 2,3 Audiovox CDM-8900 Main LCD Screen Replacement: 步骤 3 中的图像 3,3
    • The small electronic components inside the phone are fragile; take care not to damage them when completing this step.
    • Wedge one of the plastic opening tools under the phone cover near the hinge.
    • Insert the second plastic opening tool under the phone cover and slide it around the perimeter.
    • Detach the phone cover from the phone's base.
  4. Audiovox CDM-8900 Main LCD Screen Replacement: 步骤 4 中的图像 1,3 Audiovox CDM-8900 Main LCD Screen Replacement: 步骤 4 中的图像 2,3 Audiovox CDM-8900 Main LCD Screen Replacement: 步骤 4 中的图像 3,3
    • Slide out the two metal braces located along the sides of the LCD screen.
    • Carefully peel back the tape from both sides of the copper frame.
  5. Audiovox CDM-8900 Main LCD Screen Replacement: 步骤 5 中的图像 1,2 Audiovox CDM-8900 Main LCD Screen Replacement: 步骤 5 中的图像 2,2
    • Do not detach or tear any wires when completing this step.
    • Using the spudger, carefully separate the speaker and microphone from the inside surface of the phone.
    • The smaller black disc is glued down, so you may need to use some force to detach it. Both disks will still remain attached via wires.
  6. Audiovox CDM-8900 Main LCD Screen Replacement: 步骤 6 中的图像 1,2 Audiovox CDM-8900 Main LCD Screen Replacement: 步骤 6 中的图像 2,2
    • The copper frame is attached to the phone at the hinge. Do not tear the frame.
    • Gently lift the copper frame surrounding the LCD screen.
  7. Audiovox CDM-8900 Main LCD Screen Replacement: 步骤 7 中的图像 1,2 Audiovox CDM-8900 Main LCD Screen Replacement: 步骤 7 中的图像 2,2
    • With the copper screen lifted up, gently pull out the ribbon connector and lift out the LCD screen.
结论
Aaron Shaw
于04/15/10注册
159 声望
创作了6篇指南
团队
Cal Poly, Team 28-31, Regan Spring 2010 Cal Poly, Team 28-31, Regan Spring 2010 的会员
CPSU-REGAN-S10S28G31
4 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 15
总计 4,121
